Just got done rebuilding my tranny,?
Old Feb 10, 2008 | 07:30 PM
slagger's Avatar
Default Just got done rebuilding my tranny,?
Well I finished my tranny build but I went back to the stock 3-4 clutch pack,stock boost valve, I have the trans go shift kit, I do have a Question
it runs great,shifts great,down shifts good, But I notice that once you drive it for awhile i'm not sure how long prob untills it warms up when you stop at a light and take off it feels like it slips but it not because if I give it alittle more gas it start to spin my tires. it does it just alittle untill you get going about 5 or so mph kinda like the torque convertor stall.
not sure what it could be maybe my clutches have to seat or someting?
I put all new clutches,seals,bushings,
thanks
Old Feb 10, 2008 | 07:55 PM
performabuilt's Avatar
LS1Tech Sponsor
Are you sure its starting in 1st gear ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 10, 2008 | 08:05 PM
slagger's Avatar
yeah its starting in first, yesurday after I drove it for about an hour it felt alittle more but this morning I didn't feel it till later on and it felt better then yesurday.
Old Feb 10, 2008 | 08:13 PM
LS1Tech Sponsor
Thats a hard call, If its slipping it will get worse very fast, But though warmer temps could cause it to be more likley to slip from presure loss, I am not sure its one of those things where you would abut have to feel it to know what it is, Unfortunatly if it is indeed a slip it will make itself obviouse very quickly, If you have access to a presure guage you may want to conpare the cold line to the hot line they should be very close to the same might give you and idea if a leak or pump issue is the problem,
__________________
Call 888-744-6542
Old Feb 10, 2008 | 08:46 PM
slagger's Avatar
I will hook it up this weekend and see what my readings are psi.
its don't feel like its slipping and not moving its feel like theres a higher stall but its happens very slight at take off till about 5mph.
my pump was in good shape I put new bushings, and O-rings in the pump, the vains are good they have about 20,000 miles on them and are 13 vain.
I put a new filter in the pump reassembled, all new teflon seals,
i'm going to hook up my pc next week and psi gauge and see whats it reading.
Old Feb 10, 2008 | 08:50 PM
slagger's Avatar
I was getting a bump from 2-3 gear before I rebuilt it but trans go 2nd feed hole recomend .093 (in the valve body plate ) and I had the .490 boost valve. I took out the .490 boost valve and made the hole .083 it shifted good from 2-3. that was about 1-month ago so when I rebuilt it I made the 2nd feed hole back to what trans go recomend .093 and stock .470 boost valve.
it feels good now.
Old Feb 10, 2008 | 11:22 PM
LS1Tech Sponsor
I would definatly check the PSI at WOT ideally it should be somewhere between 210 and 235 psi . Low line is had to check in the car to many variables , If you can make a vid OF what it does and post that can help alot in figuring it out
__________________
Call 888-744-6542
Old Feb 10, 2008 | 11:32 PM
slagger's Avatar
sounds good,
i'm working 12s all week but will post when I get some time.
thanks
Old Feb 10, 2008 | 11:37 PM
LS1Tech Sponsor
Will look forward to it
__________________
Call 888-744-6542
