what should tranny temp be with a cooler ?
i suspect my cooler isnt doing the job anyway.
anybody know?
Are those trans temps your seeing from racing or normal driving? 220+ seems kinda high for normal driving with a trnas cooler installed.
1) you were at the track lastnight logging it?
2) driving around town logging it?
3) driving around town doing WOT runs logging it?
4) How were you logging it? Atap? by checking your stock gage or aftermarket gage?
5) what size cooler you have on.
6) What size TC do you have? The bigger the vertor the bigger cooler you will need.
I'll be keeping an eye on this one. I would like to learn from it.
Miriah
i was loggin it with a TECHII.
The cooler should be installed in series with the top (outlet)line from the radiator. The bottom (inlet)line should stay hook up like factory.
I didnt install the cooler and honestly havent really got under there to look. i do know they installed the cooler right above the air dam spoiler. The shop that did it is crap so i am having to change just about everything they did.
? TIA...
this is w/a 28,000 GVW B&M cooler and my Vig 3600
When my last transmission started going on me, trans temp would get up to 230* normal driving, and if I was going up hill the trans gauge would peg at 250...
Right now w/my new tranny, same stall and same cooler I haven't seen higher than 190 w/very aggressive driving....
Seems that I read where they like the trans temp to be at 175 or lower.
You need your fans re-set or get a fan switch.
