What is needed to install T400 into A4 car?
Old Mar 10, 2003 | 05:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default What is needed to install T400 into A4 car?
Here is what I think I need...
M6 crossmember
Custom tq arm mount
Need to add a rod end to the end of my RT tq arm which already comes threaded...
Does anyone make a crossmember that might work with my RT tq arm?
Does the T400 take up a lot of room or will the tq arm have plenty of room?
<small>[ March 10, 2003, 05:41 PM: Message edited by: Pro Stock John ]</small>
Old Mar 10, 2003 | 05:51 PM
FEAR THE LS1's Avatar
Default Re: What is needed to install T400 into A4 car?
YANK has a crossmember that works great. I bought it for my TH400 install. The Crossmember is made to use the Torque Arm bushing from Random Tech. I bought the bushing from RT but I am using the LG Torque Arm.
I did a swap from an M6 to a T400 the T400 was just a little longer than my M6, so I needed a shorter drive shaft. But the mount of the TA mount on the xmember was in the exact spot of my old setup.
I know the YANK piece is pricy, but the other options (BMR, stock mounts etc) that were cheaper still left me with having to fabricate a TA mount. The YANK was perfect.
Lee
Old Mar 10, 2003 | 06:20 PM
Holes02's Avatar
What about selling the RT torque arm and buying a Spohn unit?
Old Mar 10, 2003 | 06:28 PM
LS1Tech Co-Founder
It's a possibility.
Old Mar 10, 2003 | 07:52 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
John, I believe you are changing from an A4 right? If so, your stock crossmember will work. It just needs the pad lengthened about 2". I have some pics of mine if you want. I can't help with the tq arm though. I have a GW which bolts to my crossmember.
Get the dipstick through MADMAN. Perfect fit.
Tim
<small>[ March 10, 2003, 07:54 PM: Message edited by: Tim98TA ]</small>
Old Mar 10, 2003 | 07:58 PM
tidemandave's Avatar
I was told if you use a TH400 that there is no good way to get the speedometer to work. Is that the case?
Old Mar 10, 2003 | 10:34 PM
BIGBOS's Avatar
I use the yank speedo sensor, and it works pretty good, speed is pretty close to what it should be showing...
I think its like $250
Old Mar 11, 2003 | 07:12 AM
Tim98TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by tidemandave:
<strong> I was told if you use a TH400 that there is no good way to get the speedometer to work. Is that the case? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">WRONG!!!!!!
You have to replace the cable drive speed sensor on the TH400 with an electronic sensor. You will need 3 GM parts, (I don't have the part #'s here), for a total of ~$150.00. Very easy to change. However, if changing from a M6 you will need to have someone with LS1 Edit change your tire size to get the speedo correct. The M6 will read 2.4 times the speed. A4 doesn't need this.
Tim
Old Mar 11, 2003 | 10:21 AM
LS1Tech Co-Founder
My biggest concern is bolting up a torque arm so we can move the car around.
I'm not into the Spohn stuff how about the BMR stuff?
Old Mar 11, 2003 | 11:20 AM
MacGyver's Avatar
John,
I have the BMR Trak-Pak torque arm setup and I like it. The crossmember welds between the subframes so it's completely off the tranny. I'll take some pics of it if you want.
Will
RyanJ's Avatar
SSU Moderator
how fast do you want to go?
for me there are two choices.
1) Madman w/ its own crossmember
2) LG with Yank mount. RT works too I guess.
I here the BMR Xtreme is also pretty strong.
why not use the stocker with a floating mount (madman can prolly build you one) and some Pete-Z LCA's. Thats what I would do really.
Old Mar 11, 2003 | 02:30 PM
XLR8NSS's Avatar
Adkoonerstrator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong> I plan to go faster than all the NA guys.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Even the Colonels C5R whenever it gets going??... <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 11, 2003 | 06:13 PM
Tim98TA's Avatar
John, if you plan on starting from scratch on the tq arm and stuff, go with MADMANS setup, hands down.
Tim
Old Mar 12, 2003 | 12:06 AM
LS1Tech Co-Founder
I have some interest in the BMR system, I would not mind seeing a pic does it impair exhaust clearance?
Old Mar 12, 2003 | 07:44 AM
BIGBOS's Avatar
I used the same setup as Macgyver....works pretty well....
No problems so far w/it...
Old Mar 12, 2003 | 01:05 PM
Tom the roofer's Avatar
John, I have the BMR extreme TA installed. I can take some pics later if you are interested. I can't answer the exhaust question though. I don't have one on the car right now.
The nice thing about the BMR, Madman or Spohn TA's is you will never need to take the TA off to change the tranny again. I had the Random Tech TA before and that was a real biotch to change converters or drop the tranny.
Tom <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 12, 2003 | 07:46 PM
Tim98TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Tom the roofer:
<strong>The nice thing about the BMR, Madman or Spohn TA's is you will never need to take the TA off to change the tranny again.
Tom <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah the Global West is the same way. It simply unbolts from the tranny crossmember and stays put.
Tim
Old Mar 13, 2003 | 12:15 AM
BTL FED's Avatar
Will there be any computer issues when going from a 4l60e to a TH400? of will the speed sensor take care of that?
Old Mar 13, 2003 | 10:41 AM
LS1Tech Co-Founder
I'm gravitating to the Billingsley Racing crossmember and torque arm setup. It's like $600 but it's chromoly, and it's all there. I can just bolt in the T400 and the torque arm and I am done. Jay Billingsley took his Random Tech torque arm down to the 10.3's no problem but elected to fabricate his own setup to take 1.2-1.4 60 ft times.
