fsatest 4l60e?
Old Apr 28, 2008 | 09:25 PM
eric01ss's Avatar
Default fsatest 4l60e?
who has ran the fastest times with a 4l60e? motor,nitrous, and fi
Old Apr 28, 2008 | 10:09 PM
performabuilt's Avatar
LS1Tech Sponsor
I don't know about the fastest and he may not be the fastest we have since we go by the no video didn't happen rule lol. but the guy in the video has been regularly running low tens with our level 2 for about a year now.
Click the picture below to watch
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 28, 2008 | 10:39 PM
GT Griller's Avatar
The guy who owns the shop that built mine has had his wife go 10.30's in her daily driven tubro and spray TA, thru one of his 4l60e's.
Old Apr 28, 2008 | 10:57 PM
CalSpeedPerformance's Avatar
One of my builds on a customer/friends car is a 98 C5 427" /w RPM Stg 5 tranny with a transbrake that has ran 10.6 on the motor and 9.7 @ 148 on spray. Ive seen just over 800 rwhp on the dyno with it so far...
Old Apr 29, 2008 | 07:37 AM
Matt D's Avatar
Retired Street Racer
FLT has John Reese's Vette going 9.60s and that was on low boost last year. It should be much quicker this year. You can find videos of the car all over the net. They hold the record for the fastest 4l60e right now.
Old Apr 29, 2008 | 11:27 AM
daniel6718's Avatar
i heard it was a 9.7
i have been running 10.0 for about a year with 10k on the tranny and about 200 passes and its still fine
Old Apr 29, 2008 | 02:03 PM
CamaroRacing12's Avatar
i kno CPT also has a few 9 sec cars running his 4l60e's
Old Apr 29, 2008 | 03:37 PM
GregWS6&z28's Avatar
I have one of his and running 10.6's spraying through the shifts in my 3600lb car. it's definitely low 10, high 9 worthy.
Old Apr 29, 2008 | 05:46 PM
melchoir's Avatar
Fastest car on 4L60E that I know of belongs to LS1Queen/Chevpower from WCR.
It was a 383CI + nitrous, ran a best of
1.344 60ft
6.08@114.92 1/8
9.492@144.1 1/4
with a 4L60E that Chevpower built himself.
It later went 9.21@146 with a TH350.
Old Apr 29, 2008 | 06:52 PM
PBA's Avatar
PBA
Chevpower was using my Pro Street kit with this. He had just added a Sonnax 2nd gear apply servo and a Alto extra wide carbon 2-4 band when he spit out a driveshaft at the 1,300 foot mark. It took out the transmission. He then went with the TH350 as stated. Greg told me that the best with this was 5.78ET @121mph in the 1/8 mile, & a 9.36ET @144.6mph in the 1/4 mile. He had many passes in the mid to high nines. At the last conversation with him, he stated he will be working on a new built 4L60E.
Old Apr 29, 2008 | 07:32 PM
melchoir's Avatar
That's interesting. Last he told me was that he'd never go back to a 4L60E after picking up so much going to the TH350.
Old Apr 30, 2008 | 01:40 AM
PBA's Avatar
PBA
He wants to be able to drive to the track as before, and show what the 4L60E can do. He knows the TH350 was a little quicker, but where is the challenge. With the new motor and even more nitrous, he would like to able to get low nines, or high eights. His wife had a child recently, and I do not know if she will drive the new setup, like in the past, he did not say. He is asking a lot, but I will do whatever it takes do get there.
Old Apr 30, 2008 | 01:47 AM
daniel6718's Avatar
i would be on of them...if not dam close
Old Apr 30, 2008 | 09:49 AM
Matt D's Avatar
Is this Dana?
Old Apr 30, 2008 | 07:20 PM
PBA's Avatar
PBA
Yes........
Old Apr 30, 2008 | 08:48 PM
chucks ss's Avatar
well im needing a new transmission i cant spend over $2200 and i need a converter too , im running a 2001 ls1 with bolt ons and a 200 shot , 373 gears etc , im impressed with performabuild transmissions, any one had problems with them ,, cause right now i think thats the way im going thanks for any input
Old May 1, 2008 | 12:17 AM
ss dave's Avatar
I had one of Performabuilt Level II trannys behind my 69 with a LME built LS7, 650fwhp, Yank ss3200 converter. Went thru the initial tune and initial trial run and lost 2nd gear, burned clutches. Had a local guy rebuild it, now it works well. Working with Frank at Performabuilt, I'll know more about their customer service after they recieve the old parts and then I'll post it.
Old May 12, 2008 | 03:24 PM
LS1Queen's Avatar
I just saw this thread..
Oh Dana.. You should know better to think I wouldn't be running again. LOL Peyton is fine and my health is alot better after my stroke. I just ran the new car we picked up in Feb Saturday at BMP. I made some shake down passes with the new setup.
Old May 12, 2008 | 03:41 PM
ChevPower's Avatar
Not sure how are info got crossed but i did go 9.49@144 loosing the shaft at about 1300 feet. It was my 3 speed setup that when 5.87@121
We mostly ran the 1/8 but the trans made the 2-3 shift in the 1/8 and to me that all that counts,
Now we are working on a new 4l60e project now, Me and FTI (a converter company) is building a 4l60e with a different gear set, This trans will go behind a 440ci lsx in a 3500+ weight car, we dont know how fast we can go or how long it will last but we are looking foward to it. Are old set up had well over 300 1/8 mile passes 6.30- 6.02 and the only failure's we had was a broken out put shaft (the car was 3770lbs cutting 1.32 60ft) and 2 broken pump rotor's due to me running vaccumm modulation and loosing the line (the pumps do not like high line pressure at low rpm's)
Old May 12, 2008 | 03:50 PM
ChevPower's Avatar
I dont like the 4l60 because of the gearing but FTI says we can change that so i said what the hell lets try it and see where it goes lol
