Hard 1-2 Shift, Looking for Some Expert Help!
Some helpful vehicle specs and background:
-Purchased car totalled from a friend, the trans had 500 miles on a "complete" rebuild (according to recipt) I assume it is a completely stock setup.
-Got a rolling chassis and swapped everything over.
-Put about 7k on it since the restore so trans has less than 8k on it.
-About 500 miles ago I replaced the Trans mount as it completely failed. So I am not sure if these two could be related?!?
I tried using the search feature but didnt/couldnt find anything that seemed to relate to my situation. Some were close but were never really completely answered. Thank you in advance for any ideas help and guidiance....
16 Low Resolution Pulse Failure
32 EGR Problem
71 A/C Evaporator Temp Sens
18 Crank SIgnal Open or No signal
22 TPS to low
58 Trans Temp High
From what I have read 16 and 18 are due to a bad opti signal. My Opti did recently take a dump so I replaced it with a MSD unit. I am assuming these are old codes. I havent charged the AC yet so that takes car of code 71.
That leaves code 32, 22, and 58. I just put a new TPS sensor in it and that changed nothing. I am going to do a trans flush and see if that helps anything. (heat related) But that still leaves code 32 which I will have to maybe replace the egr.
Anyother ideas?
It will hold 1st gear until you slightly let of the gas then it will shift. (at both WOT and "easy" driving) It will hold it right up the rev limiter. Usually the 2-3 shift if fine but it has acted up on it a couple of times. The 3-4 will bounce off the rev limiter at WOT.
The car doesn't have a sector for gear 1, but I am assuming you can put it in gear one. If this is true, when I start out in "first" then hold the gas as i shift into second it still will not "shift" until I let off the gas.
Broken spring? or Bad servo?
Everything was swapped from one chassis to the other. The car I bought was simply a rolling chassis (basicly just a tub) that the guy was gonna make into a race car but never got around to do anything with it so it worked perfect for me to replaced the accident damaged parts on mine. Also everything worked excellent on it for the first 8k miles I put on it after I put it all back together.
It didnt start acting up until the tranny mount went out of it. And I mean by going up the mount ripped in two so the trans was no longer held down in the back. I didnt realize the problem until the trans came up and slapped the body.
My car is a 94 so it is pre obd-II (autozone scans OBD-II for free) but is is post doing the paper clip trick. Last Friday when I had it scanned it cost me a couple bucks. I did get some info, and then they did clear the codes. It seemed to operate the same after that.
On Sunday, the ses light came on right as I was taking off from a stop light, when the car was in first. Then at the same time that I left off the gas (to try and allow it to "shift" ) the ses light shut off. It hasnt come back on since. I ordered a data log cable today so hopefully later this week I will be able to scan for a couple codes and maybe even makes some logs so I can see if i find the problem.
Anyone have a good suggestion for trans monitoring software? Using Datamaster I was able to kinda watch what its active gear is suppose to be at cetain speeds and with cetain slip rpm and rpm16. I can email anyone the file if they can read it better than I. The active gear moves from D1 to D2 even though the rpm gauge doesnt change and you cant feel any shift. Then once you let some pressure off the gas pedal the active gears goes from d2 quickly into d3 and then into d4. Anyone have any insight?
