Trans cooler or no trans cooler?
Old Aug 11, 2003 | 09:20 PM
LS1 JAY's Avatar
Default Trans cooler or no trans cooler?
Yank says that there is no need for a cooler with the 2600 Yank, what do you guys think? When I do run it at the track, I never make more than 3-4 passes and I always let it cool down for atleast 45 minutes or so, 99% of my racing is in winter also.
Old Aug 11, 2003 | 10:12 PM
XFiveLiter's Avatar
Default Re: Trans cooler or no trans cooler?
I think a cooler w/even a stock converter is a good idea. You would be suprised how hot the trans runs with no cooler and a stock thermostat and fan settings. You live in Florida, get one.
Old Aug 11, 2003 | 10:22 PM
FrankSS's Avatar
get one if u want ur tranny to last
Old Aug 12, 2003 | 12:19 AM
CAT3's Avatar
Restricted User
Cooler YES!
Old Aug 12, 2003 | 12:57 AM
OctaneZ28's Avatar
A transmission's worst enemy is heat, so the cooler it is the better.
So yes, get a cooler!
Old Aug 12, 2003 | 10:10 AM
LS1LT1's Avatar
Get a cooler.
Old Aug 12, 2003 | 11:52 AM
Jorday's Avatar
Might not be a bad idea to use one even though that is one of the smaller converters out there. I wouldn't install a cooler with the stock converter though.
Old Aug 12, 2003 | 01:47 PM
LS1 JAY's Avatar
So what cooler should I get and how much are they?
Old Aug 12, 2003 | 05:10 PM
WJ SOM SS's Avatar
The B&M's are good. either a 19 or 24,000 gvw cooler. The 24,000 is a little thicker and will give you the best temperature drops. Might as well do a trans. temp gauge while you're at it....Also, the factory engine temp gauge sucks, so a aftermarket gauge for that would be a very intelligent thing to install, also.... WJ.
