4l60e pan and gasket
Old Jun 8, 2008 | 04:05 PM
jrob56's Avatar
Default 4l60e pan and gasket
Well here is the deal, my transmission leaks just a tiny bit and drips off one of the bolts. The fluid needs changed anyway and the leaking is bugging me, since that is the only thing on the car leaking. We changed a buddies and his was a pain draining the pan and he used a cork gasket I think. I want to get an aftermarket pan with a plug and Im sure some more capacity couldn't hurt anything.
What is a good aftermarket pan with a drain plug and maybe more capacity?
What gasket do you recommend using?
Longtubes and TSP true duals with sweet thunders will be going in when I do this as well later this summer, so will there be any clearance problems with an aftermarket pan? Any other advice or links is much appreciated!
Plans for the car as of now are full bolt ons with a 3000+ stall if that helps any.
Old Jun 8, 2008 | 06:04 PM
spy2520's Avatar
i had the derale pan, its deeper, about the size of the truck pan, but uses a standard filter, not the truck one. Its steel and it also has tubes that are supposed to let air cool the fluid better. There are several aluminum pans with plugs as well, but honestly, all pans are going to perform about the same.
Old Jun 8, 2008 | 08:11 PM
FLT's Avatar
FLT
I like the TCI aluminum pan. It comes with a drain plug and a black fibre gasket. No goofy filter extensions. Just a nice piece. IMO Vince
Old Jun 8, 2008 | 09:59 PM
3rdgentug's Avatar
i dont have one on my 4l60e but i have a tci pan on my 700r4
its a great pan, but yea honestly its not going to make things just a ton cooler, tranny coolers do that!
Old Jun 8, 2008 | 10:25 PM
cals400ex's Avatar
do you like their stock sized pan or their larger one?
Old Jun 8, 2008 | 10:34 PM
jrob56's Avatar
ya i figured they were about the same but my biggest question is would there be any clearance problems with the true duals?
Old Jun 9, 2008 | 09:41 AM
FLT's Avatar
FLT
Deeper is always better if you have the ground clearance.
Old Jun 9, 2008 | 12:06 PM
big wally 55's Avatar
Hey Vinnie, deeper is only better if you have thie right "dipstick" .
Oh I'm sorry , you were talking about a transmission .
"never mind "
