Torque converter solenoid
Old Jun 25, 2008 | 02:32 PM
FormulaZ's Avatar
Default Torque converter solenoid
Torque converter solenoid circuit code came up. I got an auto. Figure ill just replace the solenoid. Probably a dumb question but...
What is the difference between a trans on/off lockup solenoid and a 3-2 shift solenoid? And what do they do?
Old Jun 26, 2008 | 10:39 PM
FormulaZ's Avatar
Or not. Anyone at least know if its an install where I should take it in or can I do it?
Old Jun 26, 2008 | 10:44 PM
performabuilt's Avatar
LS1Tech Sponsor
First whats the number of the code you are getting and yes you can do it easily your self
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 26, 2008 | 11:41 PM
FormulaZ's Avatar
torque converter solenoid circuit was the code that came up.
Old Jun 26, 2008 | 11:45 PM
LS1Tech Sponsor
If it was the TCC solenoid there is no question about what solenoid there is only one
__________________
Call 888-744-6542
Old Jun 27, 2008 | 12:03 AM
FormulaZ's Avatar
Well thats piece of mind to know. Literally checked almost everything else that I thought could create the prob I had. All and all I will be ordering the standard motors on/off lockup solenoid and 3-2 shift solenoid from kragens auto tomorrow.
Old Jun 27, 2008 | 12:56 AM
ws6t3rror's Avatar
Why are you ordering a 3-2 solenoid when the tcc solenoid is the one that is throwing a code?
The tcc solenoid is pretty easy to get to. Its up at the very front and stuck in the pump. Held in by two iirc 8mm bolts... might 10mm. Also if I recall correctly you have to remove another solenoid to get access to it. The solenoid you have to remove to get to it will just be held in with a little spring clip and is then easily removed.
Dont forget to wash and move the screen over thats in the tcc solenoid if your new one has a place to hold it some aftermarket ones dont have a provision for the screen. Just give it a little twist and it will pull right out of the end of the solenoid.
Old Jun 27, 2008 | 08:16 AM
omcar's Avatar
delete the codes! I replaced solenoids twice before figuring this out.
