cheaper alternative to Pro Yank 3600 Extreme
I'm trying to find a decent t/c for nitrous applications. I understand that the Pro Yank 3600 Extreme is a great convertor, but I just cant see paying $1000 for it. My wife gave me the ok to spend $600. What is a good alternative to this convertor for the price range I'm trying to stay in?
Re: cheaper alternative to Pro Yank 3600 Extreme
I would like to be spraying out of the hole, with 125 shot. would the PI 3200 be a good choice for this, or should I go up to a higher stall?
Vig TC are underrated. The 3200 should flash at 3600-3800 so it is often referred to as vigilante's best N20 converter. It will stall the same if not a tad more then the yank 3600e so you should be fine with that converter. I believe it sells for $699 so you may be a bit over budget and don't forget a trans cooler for $80 and install for around $300.00 unless you can do it yourself.
It requires the removal of the transmission so I personally would not touch this job. I'll have mine professionally installed when my time comes.
So I think the vig3200 is a good choice because it's really more like a 3700 stall.
Good Luck
Good Luck
TCS makes the perfect converter for u. Its called the violator u can get 3200 3600 3800 4000 4200 or he can custom make u one for around 700 dollars they will hold 1200 horsepower and u can choose from 2.35, 2.50, 2.70, or 3.0 stall torque ratio and these converters have a 98% efficency.
I'd go with a TCS or a TCI in the 3500-3800 range. You don't need a nitrous specific converter for running a measly 125 shot.
A bigger shot is in the future, but I'm going to need to upgrade the fuel pump first, and I'm waiting on the racetronix unit. I'll pobably go prgressive controller also. Does anyone have a link or phone number for the folks at TCS? I see the sponser link for TCI but not TCS. They are two different companies, right?
LS1 Tech Administrator
You can always go with a Pro Yank 3600 without the Kevlar clutch and save $150.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
You might need to get your eyes checked. :p Look at the sponsor list again. Or, click here...
http://www.ls1-transmission-converter-systems.com/
Ws6snake-eater,
A TCI converter will do nicely for your set-up. The Super Streetfighter (3500 stall) will handle a 200 shot. It will increase your time by at least .5 sec in the 1/4 mile over a stock converter. You should be able to get the converter and cooler for around $600.
Kevin Steele
TCI
Product Engineer
Kevin Steele
TCI
Product Engineer
A C5 and F-body converter are not interchangeable.
The clutch material has nothing to do with it being able to handle nitrous unless you plan on manually locking the converter at WOT.
I'm going with the TCS streeet stalker unit with a 3800 stall, what should I use for the STR? Can anyone explain STR to me? I'm filling out the request form right now!
Colonel I did a search, and typed on STR and it gives me every freaken post that has ever been posted that contains STR. This includes everyones sig that desribes their TC. Maybe you could help point me in the right direction?
I did a search and found a few threads. One of them "What STR for a street/strip car" is right at the very top of the first page (well, before my posting now.) There was another called something like "Does STR have a direct relation on rear wheel TQ?." It's probably not far back and it too turned up on a search for "STR".
