Vigilante 3600
It took me time to learn the launch and figure the car out before I got 112 traps stock with it <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
If I 60'ed crappy my MPH was way off. If I hooked to a 1.6 or so 60 my mph hits 112. Also in hot air no one will MPH high. If you dont have headers thats about the best MPH you will see, but i dont have a clue to what mods you have??
Since you got rid of the TNT Kit, you may need to kick it up to 20+ PSI or go with a set of ET Streets to get rid of some of that resistance.
I personally think a 26x10.5 or 26x11.5 ET Street on your Prostars would be plenty with your stock internal car.
Anything more than that just roasted the tires. I set the tires at 14-15 lbs. No matter if it was the Drags, or the Streets. Good luck.
if you're runnin to little air on this ET STREETS its gonna kill your mph up top. I ran 21 psi in mine and hooked to a 1.55 cam only.
But nittos worked fine before my cam. If you have et streets its really no point in running below 20psi if you are a bolt on car and track prep is decent. Hell I bet 24-26 woulda hooked on my et streets bolt on only <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
SSean
Mike
<strong> It's interesting seeing where everyone launches from. For some reason I always get my best times launching at 1800 rpm and thats with a Vig2800. I cut 1.58 60'.
Mike </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">those are some awesome times & 60' with that small converter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong> I appreciate all the info. It seems I am stalling up to high huh. I have the e.t drags for when I spray. I still have the kit just set up different, but either way I am on gas, I will try the lower stall speed, and more air pressure and see what happens, I am going for some 12.0 best i have gotten is 12.2 but i have modded more since then too, we'll see. Next is a cam and a fuel pump and back to the juice we go.
SSean </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">keep in mind stalling up is better for spray, but leaving closer to idle is better for NA with vigs <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
so have u been 12.2 on spray or just bolt ons. That verter with headers, tires, and other little bolt ons is every bit good enough for 11.8-12.3's for sure without N20 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
