whos got a pt4400 in a daily driver?
my car is about a 3650 race weight on the street and i have 3.73s. how will this converter be with that setup? and how about fluid temps? about the same as my vig 3200?
also...hows it if you spin too hard? the car i drove shifted into second immediately and would bog since we were going too slow for second. he said that hes got it down so it doesnt do that though.
i hope my car still goes as fast with a bigger converter
Anyways, I have a 4400 as a daily driver and its not as bad as everyone thinks. I like it alot youll be fine. Just get a tranny cooler if you dont have one like a B&M Supercooler.
i was afraid i wouldnt gain going to a different converter...but i dont see how i couldnt gain now. it will put me right in the power range all the time. my converter hits incredibly hard off the line (best of 1.47) but i always thought it left something to be desired everywhere else- just too tight. i dont know if i 60' so well cause of the converter or the car or something else. it went 1.8s with the stock verter <shrug> time to find out if i can do better
Where do you live at?? Atlantis???
(LOOSE) and with 4.10s, was not bad. I never had a 3200 to compare it to, but it pulled hard. Kinda wish I still had an automatic, but, oh well. I don't see how you couldn't pick up, the TP4400 is such a proven convertor, but your car is a freak to begin with. I'm just trying to keep up with you, and I have heads.
You have a PM, by the way.
I probably wouldn't switch if you can consistently pull very low 1.5's. This isn't to say that you might not be able to pull mid 1.4s consistently with the upgrade, only that your combo is working right.
shawn- i sent you a pm back. i havent had a chance to call you cause ive been really busy lately
Shift extension and efficency are way better also (you should pick up a little more MPH.)As far as looseness and street driving goes, I raised my part throttle shift points and lowered lockup MPH (thanks Ragtop). Also, it generates a little more heat, so I gonna get a bigger cooler. Its only a problem when it really hot out. I sometimes see 200 on the gauge in stop and go driving.
