???tranny Slipping???
Old Aug 16, 2008 | 10:16 PM
nemss1's Avatar
Question ???tranny Slipping???
when im cruising at 70 and floor it, it shutters. i put a scanner on my car and it doesnt read anything wrong with the tranny.
my car does need a tune bad. could this be it???
Old Aug 16, 2008 | 10:30 PM
FLT's Avatar
FLT
I guess what you have to determine is this a lock up clutch that is chattering or if you have driveability issue with the engine. Vince
Old Aug 16, 2008 | 11:05 PM
nemss1's Avatar
would i have to replace the lockup clutch if that was the problem?
it may be something with the engine. i didnt throw any codes for the tranny
Old Aug 17, 2008 | 12:29 AM
FLT's Avatar
FLT
Do you have engine related codes? If it is a lockup clutch issue you should get a 1870 code. If the clutch is bad then the converter will need to be opened up and checked out. Vince
Old Aug 17, 2008 | 01:00 AM
nemss1's Avatar
no, i dont have any of those codes.
would running lean or rich cause this?
Old Aug 17, 2008 | 01:11 AM
nemss1's Avatar
could any of these mods cause the car to run lean or rich and cause the tranny to act like this? i havent had a tune yet
PERFORMANCE
MSD 8.5mm Superconductor spark plug wires
AIT sensor timing advance
K&N CIA
Hypertech Powerstat 160 degree
descreened MAF housing
ported & polished MAF housing
ported & polished TB
TB bump stop mod
TB coolant bypass
gutted cats
Flowmaster 80 Series
Shortbelt mod
3.73 gears
ASP underdrive pulleys
rear o2 delete
Old Aug 17, 2008 | 08:46 AM
bigpapi211's Avatar
flooring it with any auto other than from a dead stop is bad. 4l60 is not rolling race friendly. plan to break many things if you keep driving like that.
Old Aug 17, 2008 | 03:04 PM
nemss1's Avatar
so its bad to floor it at 30 and 70 to let the auto tranny downshift???
Old Aug 17, 2008 | 07:09 PM
9000th01ss's Avatar
wow
Flooring it isn't going to burn the trans up.
Flooring it at 70 should cause a downshift.
Here are two videos I had already, there are three 4-3 downshifts, one at wot.
This one I was trying to not let it downshift http://www.youtube.com/watch?v=iv7jlr6LpbE
This one is a wot downshift http://www.youtube.com/watch?v=Eb4DUGWhAqM
I built my trans, not worried about it burning up. And if it does I'll build it better.
Old Aug 17, 2008 | 08:35 PM
nemss1's Avatar
Originally Posted by 9000th01ss
wow
what would cause my tranny to move then kick then move again when i floor it at 70? it doesnt do that at downshifts at 30. maybe i need a tune on the engine? my mods are listed in a post above. would a lean or rich mixture cause the motor to make it drive like that?
Old Aug 17, 2008 | 08:50 PM
TedsB4Csled's Avatar
Get a transmission shop to look at tranny. If you are in need of a stock converter with only 3k miles, PM me. Goodluck.
Old Aug 17, 2008 | 08:56 PM
nemss1's Avatar
wouldnt it show up on a scanner if the tranny had problems? could it be my converter?
Old Aug 17, 2008 | 08:58 PM
9000th01ss's Avatar
It sounds like an engine problem to me.
I'd manually downshift it and see what happens.
I'd guess a lean condition. It's hard to do over the internet as you know.
Maybe check the fuel pressure, thats easy and can be done for free if you rent the gauge.
Maybe pull a spark plug out, make sure it's not dark (rich).
Make sure the wires are on good, seen a few posts about that causing problems. What about the spark plugs? I've seen posts about cracked plugs causing problems too, not too hard to put a hairline crack in one during installation.
Old Aug 17, 2008 | 09:17 PM
nemss1's Avatar
i may be running rich or lean with the mods ive done. i still need a tune and tune things out. i have had detonation/ping. could detonation and ping cause drivability issues with the tranny? i think my old plugs i just changed were black. does a lean or a rich mixture cause detonation/ping?
Old Aug 17, 2008 | 09:49 PM
9000th01ss's Avatar
Lean causes a ping, rich makes plugs black. Rich conditions also foul plugs (misfires) and O2 sensors.
Thats a good place to start, getting it tuned.
Old Aug 17, 2008 | 10:45 PM
nemss1's Avatar
could running lean or rich cause when i floor it at 70 and it will move, then kick, then move again?
Old Aug 17, 2008 | 11:50 PM
9000th01ss's Avatar
Like it's dropping a cylinder out? Yes
It should downshift. If not, manually downshift it to 3rd and see what it does.
Old Aug 18, 2008 | 12:59 AM
nemss1's Avatar
ya it does downshift but its really rough
Old Aug 18, 2008 | 05:29 AM
FLT's Avatar
FLT
Engine misfires such as detonation will cause your converter to lock and unlock. Get this car to a tuner before you blow something up. Vince
Old Aug 18, 2008 | 03:22 PM
nemss1's Avatar
vince, your explanation makes sense. i think this could be the problem. detonation causing my converter to lock and unlock
also, i had another question. would a misfire cause my SES light to blink? my light isnt blinking but it does stay on. no tranny codes. just engine related codes
