I just got a 4L80E for rebuild pics.
I bought the trans as a core, and I'm a 6-speed (M6) ,and Ive had fun with it, but now its time to get down to business. The engine is getting to big and powerful for a stock M6. And i want to be consistent with my runs. and will be starting my LS3 434cid this spring. And im getting tiered of all the shifting and clutch work.
Would it be a good idea to find a set of 5 pinion planetaries instead of the factory 4, do i need to change the drum and all or just the planets then self.
I took the trans apart and noticed that the center support is not the right one for the 04 models . The end were it supposed to be machine down .040" (recessed)for the thrust bearing ,Its not , its flat. But it bolted up in the case . What is wrong here ,is there mismatched parts in this tranny !!!
Hey Randy I was just wondering what you were going to use to control the tranny. Im looking to do the same thing (currently an m6) and I dont know which way to go about it. Thanks, Joe
