tranny problems
Old Oct 4, 2008 | 08:45 PM
TravisMcGill2000's Avatar
Default tranny problems
i was at the track last night and on my 3rd pass the car hit the rev limiter shifting from 1st to second. after i stop the car wouldnt take 1st gear. i let the car cool off and the car took first and shifted normal. so i go bak up and run again the ame thing happens it hits rev limiter again just going from 1st to 2nd. car has a tci street figter stall. anyone with any ideas
Old Oct 5, 2008 | 02:55 AM
performabuilt's Avatar
LS1Tech Sponsor
Are you getting any ses lights/codes?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 5, 2008 | 07:29 AM
FLT's Avatar
FLT
Definitely sounds like you are probably getting a code for a P0751 which is caused by higher stall converters. Basically when the code is thrown your trans goes into a limp mode. If so you will need to remove the test for this code with tuning software and I would also remove the P0757 test as well. Vince
Old Oct 5, 2008 | 09:34 AM
this is the first time the car ever did that. i pulled a 1.57 60ft and it never done that
Old Oct 5, 2008 | 11:41 AM
LS1Tech Sponsor
Thats the strange part about these codes they can come up regularly, randomly or not at all But as Vince mentioned the test for these codes should be removed IMO with and high stall converter when the car is tuned for the stall. But I have noted from as often as this comes up many tuners to not?
__________________
Call 888-744-6542
Old Oct 7, 2008 | 08:48 AM
goes a 94 have tq manegment i have seen no gain with my new 10in 3200 stall
Old Oct 7, 2008 | 11:08 AM
Old Oct 10, 2008 | 07:20 PM
z28matt's Avatar
i dont think the 94's do, but you have a trans cooler right? if not you need one.
Old Oct 13, 2008 | 12:50 AM
bluchev's Avatar
put the biggest cooler thatll fit!
