Road and Track ZL1 vs GT500
Wrong. That's rear end GRIP at work. The Shelby's less optimal front to rear weight distribution ratio is made all the worse by not having enough rubber under the back end...all the while trying to plant nearly 100 more horses to the ground. This is one place where the ZL1's weight actually works in its favor. More weight over the backend = more composure in the corners. Then you throw in the magnetic suspension on top of that and this is what you get. The Shelby...once again...just isn't able to use as much of its power as the ZL1 can on the track. Has little to do with how rigid the chassis of either car is. I assure you both chassis are more than up to the task.
You can tell by watching the cars that the Shelby is much less predictable. In a couple of spots in the vid is was pushing like a dump truck right into a snap loose situation. That's the chassis giving up. Tires could mask it for a while. But more than likely it would aggravate it once wear started.
***Repost Police***
There will be GT500s in the 9s no problem with the stock blower. The shortblock can take over 1,000rwhp. LSA can't do that. And we all know how much you value abilities using stock parts.
There are pick-up truck ls shortblocks running around with 800+ whp on pump. What makes you think the lsa won't do it? How do you know that 5.8 is good for 1000hp? Do you have one? 03-04 termi's was suppose to be good for alot of power. I have one that blew up @ 458.
There already are. ![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Although the very first one to do it (Evolution Performance) has since blown their stock 2013 GT500's engine up after they hit 9.6.
Still damn impressive though.
Point taken.
***Repost Police***
And there are '03-'04 Cobras with 800rwhp that are regularly driven. The 5.8 is a bigger 5.4, so there is no reason to believe that they won't at least handle as much power. Are you arguing that the cast LSA is stronger than the forged 5.8?
The gt500 is on 15lb of boost. It's not gonna take much more and it's gonna need a alternative gas, the ZL has plenty of room to grow in the boost department. And it will make more power on the same amount of boost. When serious mods start to happen it's all Zl then. 400+ cubes and boost, The gt500 can't get there.
Earth.....and the land of common sense.
You guessed part of it.
#32
Please post a link because that would make them the fastest so far but I guess they don't want to brag since they blew the motor up going for it huh?
#33
Also fyi.....I don't car what either makes on race gas. So putting a splash in one or the other is not in the conversation.
The lsa has been in the cts-v.....it gets to the 10's pretty slick in a bigger heavier car. Last time at the track I watched a stock auto CTS-v go a 12.1 on just a dr.....and out run the 5.4 gt 500.
#34
Don't bother, he's just going to keep throwing the "I haven't seen it with my own two eyes" flag, along with pointing out more Terminators that "he's seen" blow up with under 500whp, then he's going to argue the 4.6 is basically the same as the 5.4, and then he's going to point out how many hundreds of stock truck blocks are making over 1000whp, etc, etc....you can't win arguing with nutswinging idiots.
#35
I know exactly what it is. It's a bigger 5.0 with forged internals. Ford did a great job on it. But mod for mod the bigger motor will win. And upping the boost on the ZL is gonna make a huge difference.
![](http://i0.kym-cdn.com/entries/icons/original/000/000/554/facepalm.jpg)
#36
![Ridin' the sack](https://ls1tech.com/forums/images/smilies/sackrider.gif)
remember Irunelevens has never touched the 13's.
#37
#40
A 2013 gt500 needs a pulley, intake, Throttlebody and headers to be over 700whp, and that is in 100 deg weather. Notice it is still only on 15.x lbs of boost so you could run an overdrive lower if you really what to spin it hard.
http://www.fordgt500.com/forums/showthread.php?t=16819
Also, the griggs suspension also VASTLY increases rear end grip with the torque arm.
