Looking for a Motor Trend article, Mustang vs Z28
Looking for some motor trend article...
My buddies were telling me about some motor trend article where they built up a few cars for the track among them were a 98 Z28 and a Mustang 5.0. They said they did all kinds of things to the cars, cammed both of them , lightened, whatever.
They said the 5.0 was running low 10s and the Z could barely cut 12s! WTF is up with this ? A cammed LS1 barely able to pull 12s just doesnt sound right at all to me ( on sticky tires no less )
So has anyone read this article ? Is there something I'm missing here?
King of Pigskin Knowledge
Never seen it, but I wouldn't doubt it. I'm just surprised they didn't add a foreign car, get it running 15's with mods,then declare it the shootout winner b/c it had better "refinement, build quality and ergonomics".
Originally Posted by camaroextra
sorry motor trend can suck my **** after the boxter beat the z06 in a sports car test
THAT'S why I cancelled my subscription in the late 90's. Why bother doing performance tests to come up numbers and shootouts when:
1. The numbers are almost always worse than your average driver can get
2. You ignore the numbers anyway and almost always declare the foreign/less performing car the winner based on SUBJECTIVE items
Restricted User
Originally Posted by Blakbird24
I'd call BS on this one. First of all, Motor Trend doing ANYTHING with a 5.0? Unlikely. Comparing an LS1 to a 5.0? Highly unlikely. The 5.0 outperforming the LS1 with what i'm sure they would try to make "comparable" mods? Impossible. Not that the 5.0 isn't a pretty damn good engine, but it's in a different ballpark than the LS1 in my mind.
I've never seen MT do a comparison of modified cars. I've seen articles on modified cars, but they are usually specialty cars, by Lingenfelter, Ruf, Dinan, etc. Also a 5.0 vs. an LS1 sounds wrong because those cars are what, 5 years apart? Might as well do a comparison test between a 72 455 TA and a 77 TA.
Well when my friends were telling me they made it sound like it was a budget buster type of build up. Which one can go faster cheaper, in that case I might believe the 5.0 just because the aftermarket is so gigantic... but I'm not even sure if 5.0 aftermarket parts are cheaper...
Restricted User
Still, mod for mod, a 5.0 ain't gonna catch an LS1.
The most obvious evidence of BS in this case is the claim that Motor Trend did anything with a 5.0. MT would definetly use the 98+ 4.6 in a comparison like that. I'd be inclined to consider it if we were talking about Hot Rod Mag or something alone those lines, but not MT.
GM High Tech Performance had an issue with a 96 Cobra and 96 Camaro SS comparison.
MM&FF also had a comparison...
http://www.musclemustangfastfords.co...ff_deathmatch/
CJ
CJ
sounds like your friends are just a bunch of mustang fans and are trying to rattle your cage. First off why would they pit a early 90s 5.0 against a 98z28? think about it. I've been reading motor trend for a while and I cant ever recall them modding a car.
cammed z28 barley getting 12s? lol must have had the stock cam then! 5.0 in the 10s (on all motor)? lol...must have been HEAVILY modded.
I know you can check out the Motor Trend website and search their archives.
You're probably thinking about the infamous black ZL1 vs orange Boss Mustang comparo that Car and Driver did a few years back, not Motor Trend. John Coletti and the SVT boys threw together a bad *** 10 second Mustang backed by a 3 speed automatic and packing some huge cubes. John Moss and the GM guys origianlly built a 572 powered 4th gen backed by a 5 speed stick and at the last minute changed the motor for something even bigger. They ended up doing a strip run and a road course run. The Mustang owned the Camaro in a straight line by about a second (I believe the Mustang was into the 10s with the Camaro somewhere in the mid 11s) but the Camaro despite having major engine trouble as well as tranny problems ended up taking the Mustang on the road course. C&D called it a tie. It was nothing more than the big guns of each camps performance division fooling around and seeing who could throw up bigger numbers. A pretty good article IMO. It happened like 4 or 5 years ago IIRC.
FWIW Coletti and company used an SN95 body Mustang and not a Fox Body. However they used one of the earlier horizontal tailight models ('94-'95) that still packed the aging 5.0 in GT, Cobra and '95 only GTS trim which is why your friend might have said they used a "5.0" However this car had it's stock 5.0 replaced by something much nastier anyway.
CJ
CJ
Restricted User
That's the only one i've seen, but I think it's an ongoing matchup.
