A detailed look at GM's LS motor plans... cool info.....
http://www.leftlanenews.com/a-detail...tor-plans.html
With so much incorrect information out there about GM's future LS motors, we though it would be a good time to query our sources and get the real deal. From the Cadillac CTS-V to the Corvette ZR1, we take a look at the LSA, LS7, LS8, LST, and LS9.
LS7
This is, of course, the current 7.0-liter, naturally aspirated motor in the Z06. It's handbuilt at GM's Wixom performance center and is very expensive to make. Too expensive with the LS9 motor coming. While there will be several months where the LS7 and LS9 will be built at Wixom, the LS7 will eventually die, probably sometime between late-2009 or mid-2010.
Several publications have repeatedly insisted the new CTS-V will be powered by the LS7, but this is completely false. GM cannot spend engineering dollars on a CTS-V to start with the LS7, then 12 to 18 months later, switch motors after the LS7 is discontinued. Rather, the super Caddy will feature an all-new powerplant.
LSA
The LSA will find its way under the hood of the 2009 Cadillac CTS-V. The LSA is a 6.2-liter, smallblock V8 with a supercharger. It features an intercooler integrated into the intake manifold.
Preliminary specs have it over 500 horsepower with a choice of manual or automatic transmissions. The CTS-V will start production in September of 2008 with this motor. Look for around 6000 to 8000 units annually.
Original plans also had the LSA going into an Escalade V-series truck. However justifying the development cost — not to mention CAFE considerations — might put possibility of such a truck in jeporady. At present, it is unclear whether the Escalade-V a truck is still part of the plan.
LS8
This is another 6.2-liter, smallblock V8 with a supercharger. It also features an intercooler integrated into the intake manifold. This will be the motor going into the top-end Zeta platform cars. The most premium Camaro, probably called Z28, will get this motor.
That said, original plans had this motor going into a Denali SUV or truck, however, those plans now seem to be canceled. Again, this maybe a result of CAFE.
Some of Holden's vehicles may also get this motor eventually. Initial specs have this motor at 475 to 500 horsepower with a choice of manual or automatic transmissions.
When the LS7 dies, the Z06 will get this motor. Possibly, slightly uptuned from the version the Zeta cars would get. This motor will start production in first or second quarter of 2010.
LST
Yet another 6.2-liter, smallblock V8 with a supercharger. It also features an intercooler integrated into the intake manifold. This motor may or may not still be in GM's plans. The original plan was to put it in GM's Heavy Duty trucks.
Delivering in excess of 450 pound-feet of torque, it was set to start in the middle of 2008. However, it now seems this motor may no longer be part of the plan. GM may have decided its diesel offerings were sufficient. It's also possible GM had a hard time justifying the cost of development. Of course, CAFE might have also played a role.
LS9
This is the 6.2-liter, smallblock V8 with a supercharger going into the ZR-1 Corvette. Like all the others, it has an intercooler integrated into the intake manifold. Original specs had this motor at 600 horsepower and 550 to 560 pound-feet of torque. It now seems the horsepower rating may have jumped to as much as 650.
If that's true, it would probably be safe to estimate a similar jump in torque to around 600 ft lbs. Sources have stated the LS9 can make 700hp on a test stand. Obviously though, that is without a car attached to the motor. Don't look for any production hp number starting with "seven."
It now appears an auto/paddle shift may also be an option on the ZR-1. This motor will be handbuilt at GM's Wixom performance center. They will only make 1500 to 2000 units a year. Production of the ZR-1 starts in July of 2008.
LS7
LSA
LS8
LST
LS9
14 Second Truck Club
Although I believe some of it might be true, a lot of it looks like speculation. I would like to know the source first off, then maybe form an opinion on what the article says.
Odd... so many bashed for for "having to put a supercharger on to make power". Now it seems that GM has taken the blower route to getting the smallblocks to the next level while still meeting durability and emissions standards.
When trying to get to 450-500 hp we bashed. The GM pushrod engines did this naturally aspirated. The new engines are said to make 600-650. You want to try that normally aspirated? That would take a gas guzzling 454. Not production motor territory.
Very happy to see that the Camaro will bve getting a charged 6.2L. Hopefully the trans and rear will be overbuilt this time around. Also i hope the engine will respond to mods like the Cobras and current LSX engines do.
I will deff. be putting $$ away for a top dog Camaro.
Sucks that they will discontinue the LS7, and whats with everything having a f*cking supercharger? I'd rather have the LS7 than any of those supercharged motors, excpet for of course the LS9.
-Joel
-Joel
Would the OHC engine follow the LS nomenclature? Like reintroducing the LT5?
I second the whole supercharger fetish that appears to be going on. Yes, it's awesome, but with the amount of CAFE things being mentioned, I'm curious that they are using superchargers rather than turbos. I might be a bit confused on that part.
And I'm very curious about the supposed paddle shifter for the ZR1 that they mentioned (might those be the super high gear ratios floating around sometime last year?)
While I have no problems with superchargers... It doesn't quite make sense to me why there would be FOUR 6.2l V8s, all with SC's. Seems a little like overkill, unless they're being designed with four different chassis in mind (trucks, vettes, zeta cars, CTS's). I wonder if some will die out, and we'll be left with two blown 6.2's: one for the vettes, one for the rest.
