did anybody cut springs yet or not?
That's what she said...
I was thinking about doing this too, as my Camaro has cut rear springs and works great. Who's going to do it first on their V?
1-2-3 NOT IT!![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I was thinking about re-drilling the hole in shock (the lower mount) so that the shock would sit lower and trick the self-leveling effect. This way I could leave the upper bushings alone, and maybe even do it without removing the shocks from the car. I don't have time to mess with it right now, but it may be something you can look at David.
1-2-3 NOT IT!
naw i bitched out, my spring copressor fell through and the rear spring removal was more 'involved' than i care to do multiple times. ill just save up for the gc kit.
it was neat to see the rear end drop 3/4" without touching the stock rear spring by moving the spacer from under the car to on top of the rear shock.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Sounds like you can lower the whole car without buying anything
http://www.cadillacforums.com/forums...test-pics.html
and here ya go
http://www.cadillacforums.com/forums...whl-style.html
The front is just lowering the perch clip on the strut
, lowered .75". Nothing else to the front. On the rear cut part of a coil off, I did 5/8 of a coil and then use the wildwhl spacers to fool the shock.. It seems great so far and I really do like the way it turned out..
and here ya go
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
