Voodoo Performance CTSV Strut Tower Braces
Yeah, so it looks like Im going to start producing all kinds of crap for the V's. Im having waaay too much fun building race car parts, so I figured I might as well make some money while doing it.
All prices include shipping.
Front Strut Bar:
Mounts in stock location, 1" X 2" X .125"(1/8") wall box tubing attached to .1875(3/16") mounting plates. Black spray paint standard, specify if you want bare steel.
welds exposed - $200
smoothed welds - $250
Painted, welds exposed - $280
Painted, smoothed welds - $320
Rear Strut Bar:
Requires minor trunk panel cutting. 1.5" X .125"(1/8") wall tubing attached to .1875(3/16") mounting plates. Black spray paint standard, specify if you want bare steel.
welds exposed - $150
smoothed welds - $200
Painted, welds exposed - $220
Painted, smoothed welds - $270
*The smaller bar in the image of the rear strut bar was my 1 inch prototype (same size as Lindsay Cadillac), I feel it still allowed too much flex in the rear of the car.
**Paint colors available: CTSV Black, CTSV Grey, CTSV Stealth Grey and CTSV Arrest Me Red. Other colors are available, PM me on those.
Other "Voodoo Performance Parts" to stay on the lookout for:
Offset Rear Trailing Arms for wider wheels
Rear Toe Rods
KARS III Kits
3 piece sway bar kit
Front Strut Bar:
Rear Strut Bar:
Rear Toe Rods
KARS III Kits
The factory bar is flimsy. Seriously you can push on it with your hand and it will bend. Not the same bar, but his looks in similar size to the BMR unit so here's a 'comparison' pic:
Obviously with the stock bars the body still sways, but it doesn't feel like it moves around as much because the body doesn't distort. Does any of that make sense?
dont take this the wrong way, im not trying to be a dick but if you want to sell those products especially for those prices you should work on cleaning up the welds. a little more penetration with a lil more consistant rod should do the trick. unless your mig welding slow down the rod and turn up the heat a bit. just a suggestion. good luck with your sales i like the idea!
true. Cool products man. If i were more into track i would definately be interested.
Not to question your certification but who exactly is it through? Is it AWS, API or ASME? These are the only certifications that are really recognized. Also what level of certifications do you hold? I have read and heard you talk about grinding welds which is completely unacceptable with any of these certifications. Do you mind producing your certification number?
Thanks.
Thanks.
He's not selling anything anymore, you would have known that if you had been around a little longer like Voodoo has. You bumped a worthless thread, and gave your worthless opinion.
