Hotchkis sway bar kit worth it?
i dont track my car so will i feel it just backroads driving. I am new to the handling department, main suspension i did was to get the car to hook in a straight line. btw the gf might not like hotchicks coming to my door lol.
Does anyone still use the stock endlinks then? Or should those be upgraded to in order to handle the more force thats going to be exerted on them? Another words have people had troubles with the stock ones breaking? If anyone has upgraded what has anyone had good luck with?
Looks like Buck might be my new best friend. Hook your fellow Maggied brothers up. Especially the ones with the rich tune
The Z06 endlinks are shorter and stronger. You put them on, when you lower your car. The stocker is like a twig, and may break.
As for the drilling, you have to make the hole bigger on the sway bar and lower control arm.
Tony
Tony
sounds to me like if you aren't tracking the car you dont need the sways or strut bars..
I still think the car leans bad during the hard right turn on the way to Kroger. Are the sways gonna fix this? I never understood if I needed sways, springs, strut bars, or all of the above.
saw an old thread on the limited GM sways, they sounded badass.
stiffer springs obviously don't compress as easily so that helps keep the ride height from changing and keeps the car level.
shocks help return the springs to their normal height after initial compression (like hitting a bump or hard cornering). so the stiffer the shocks the faster they accomplish this, and the more resistant the outside wheels' suspension pieces are to staying compressed after that initial weight transfer.
strut bars prevent body flex, which is essentially another form of compression during weight transfer.
upgrading any of them will help your handling, and strut tower bars will have the least effect on ride comfort, followed by sway bars. well unless you were to get adjustable shocks, but that is a different story.
