Swapping a cam without removing the AC condenser???
i know there is a technique to doing it without DCing the condenser on an LT1 camaro. but i couldnt figure out how to do it when i swapped my cam in the caddy.
but i figured there may be someone out there who is sharp enough to figure it out.
it would make the cam swap 100 bucks cheaper if we didnt have to recharge the AC every time, and would be some good knowledge for guys who are looking to tackle a cam swap....
Jeremy
Jeremy
Easily done without removal. Simply stabalize it up and to the side just enough to slide the cam out/in. Watch those A/C lines as you stabalize it! You don't want anything to bend/snap. Go slow and think it thru. Set yourself up for success. Its really simple bro.
I had mine hanging at a angle from the hood lath.. Just gotta be gental with the a/c lines but they will move enough.
I was going to take a pic when I did it but it looked so ****...
are you upgrading from the hot cam ?
(It took me a bit longer then most because i had a very poor quality valve spring compressor)
