Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What Subwoofer you guys running?
Old 05-20-2010, 10:23 AM
TheLAW's Avatar
Originally Posted by raven154
I would install that in the trunk right after the Bose amp. That converts a high level to a low level RCA. Just pull right out of the Bose amp and then into the new amp from the LOC.
How would it sound if you just took an amp that accepted high level input? That's what I was going to try and if that sounds like **** then install a LOC.
Raven,
Your second paragraph is exactly what I was hoping to accomplish. I am curious to see if there is a way to "chain" the new, sub amp into the existing Bose amp without having to use a "speaker wire to RCA" unit......
Any ideas?
LAW
Old 05-20-2010, 10:24 AM
ITSAV's Avatar
thats actually a good idea, as the amp is right there anyways......would be easy to run the wire than as well, as you dont really need to with it there....
Old 05-20-2010, 10:31 AM
87vertgt's Avatar
Heres what Iam working with...I dont like the opening under the radio but thats the only kit i can find locally....
Attached Thumbnails What Subwoofer you guys running?-dash-006.jpg   What Subwoofer you guys running?-dash-007.jpg
Old 05-20-2010, 10:43 AM
TheLAW's Avatar
I know the stock amp is in the truck.....but exactly where?
LAW
Old 05-20-2010, 11:33 AM
raven154's Avatar
The stick amp is on the left side. Pull the liner back and it's right there to your left.
Old 05-20-2010, 12:30 PM
TheLAW's Avatar
Thanks buddy.
LAW
Old 05-20-2010, 12:32 PM
TheLAW's Avatar
Do you guys think that just upgrading the sub and keeping the stock amp running it would be worth anything?
After looking at the magnet on that weak a$$ sub last night, it surely couldn't hurt!
I may try just replacing the stock sub with, lets say, a Kicker 10" free air and see how it sounds.....then if it isn't enough, buy a amp to run the "new" sub.
What do y'all think? Anybody try this?
LAW
Old 05-20-2010, 02:50 PM
CORNER CARVER's Avatar
Anyone try running an amplifier off of the input from headunit to the bose amp in trunk?
I was told by a local shop that this method would get distortion?
Audio Amplifier C2 (U57)
Connector Part Information
• 12110206
• 24-Way F Micro-Pack 100 Series (L-BU)
Pin
Wire Color
Circuit No.
Function
B1-B7
Not Used
B8
L-GN
1948
Right Low Level Audio Signal (-)
B9
D-GN
1947
Left Low Level Audio Signal (-)
B10
TN
511
Left Low Level Audio Signal (+)
B11
L-GN
512
Right Low Level Audio Signal (+)
Old 05-20-2010, 03:52 PM
ITSAV's Avatar
^^^^^^^mine had horrible distortion when it was hooked up to the stock headunit....i couldnt stand it at all....
Old 05-20-2010, 06:38 PM
87vertgt's Avatar
LAW
The quality of sound might improve but the loudness of it will stay the same.....
Old 05-20-2010, 08:11 PM
BAN-LS1's Avatar
The kicker free air needs A LOT of power. It will not even be as loud as the bose speaker.
I used a high low converter and mounted my amp under the package tray. You will have to get some MDF to mount to the package tray and then mount the speaker to that.
http://www.cadillacforums.com/forums...ker-sub-2.html
Old 05-20-2010, 08:13 PM
  #32
BAN-LS1's Avatar
Also make sure you tape and foam tape all the plastic stuff that is attached to the package tray or it will rattle like hell!!
Old 05-21-2010, 12:42 PM
  #33
ITSAV's Avatar
here are some pics I took of my sub and amp that I have set in my trunk....I couldn't get great pics with the ways its in there, but you get the idea
Old 05-21-2010, 01:23 PM
  #34
heavymetals's Avatar
Here is what I use and how I wired it.
(sub is no longer available)
Attached Thumbnails What Subwoofer you guys running?-amps-speaker.jpg   What Subwoofer you guys running?-bose.jpg   What Subwoofer you guys running?-bose2.jpg
Old 05-21-2010, 01:39 PM
  #35
TheLAW's Avatar
Heavymetals,
What sub is that? Running it free air?
Also, thanks for the pics of the wiring, but can you explain exactly how you did it and what you used (speaker wire to RCA components, etc.)?
Thanks in advance,
LAW
Old 05-21-2010, 01:44 PM
  #36
Free air sub (Infinity 1040w)
The wiring is simplistic.
Took the subwoofer connections and ran them into the amp inputs (speaker level).
Took the amplifier output and connected to new sub.
Had to remove about 1/4" off the id of the hole to get it to fit.
Voila!
Old 05-21-2010, 02:08 PM
  #37
TheLAW's Avatar
Voila!
Let me be more clear:
How did you wire in your sub amp to the existing Bose amp to get an audio signal and to avoid the distortion issues mentioned above?
How did you tie into the stock stereo (or did you tie into an aftermarket head unit)?
LAW
Old 05-21-2010, 03:01 PM
  #38
Like I said, I ran the original sub woofer speaker wires to the amplifier input (speaker level/high input) and then ran the output of the amp to the new subwoofer.
No added distortion.
Also, if your trying to make a CTS-V an audio "shrine", forget it.
However the OEM sub doesn't even make a good doorstop.
Here is a good supply house for drivers:
http://www.parts-express.com/home.cfm
Old 05-21-2010, 03:14 PM
  #39
raven154's Avatar
That is exactly what I was going to do. Thanks for the info.
Old 05-21-2010, 03:19 PM
  #40
Your welcome.
Make sure you phase it correctly.
Quick Reply: What Subwoofer you guys running?
