Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
V Cam
Old 06-28-2010, 10:30 AM
SoCA04V's Avatar
Originally Posted by maxspeed05V
some guy on the other forum had him spec a cam and the numbers were not impressive at all. I say talk to you local tunner.
That would be me.....shitty numbers, but drivability is great. I would go with a much different cam if I did it all over again.
Old 06-28-2010, 10:34 AM
ColeGraham's Avatar
what kind of numbers we talking here?
Old 06-28-2010, 11:10 AM
SoCA04V's Avatar
222/226 597/598 +3 115LSA, K&N Intake, and muffler delete....
366/355
Old 06-28-2010, 12:55 PM
vmapper's Avatar
That cam above is barley different than stock... again, looks like this is for an LS6 and again, that higher lift isnt going to do anything with LS6 heads stock at least. Its in the FLow numbers, they dont increase and I bet you had to blow $$ for valvetrain upgrades.
hard to say how well it was tuned... but Those durations are not a hell of a lot better than the 02+ LS6 cam, hence the mediocre increase.
Old 06-28-2010, 12:57 PM
ColeGraham's Avatar
all i know is i am ready to get home, put the current mods i have on, and drive my car...this whole buy a car that i have wanted for 6 years, and not drive for 10 weeks is eating my car soul...
going to be a bit of a change and take some getting use to, since i have been driving a ford turck for the last 4, almost 5 years...
Old 06-28-2010, 03:31 PM
SoCA04V's Avatar
I paid a pro to spec my cam with the assumption he would take those things into consideration. I requested a cam that had a mild idle and that would work with stock manifolds and high flow cats.
The tune is definitely not the issue, I think the cam is just on the small side.
Old 06-28-2010, 05:40 PM
maxspeed05V's Avatar
Dnt feel bad. Im on my second cam.
And if I would still go with a slightly diffrent cam if I could do it all over again.
Old 06-28-2010, 06:36 PM
itsslow98's Avatar
the only thing similar between that cam and the stock ls6 cam is that the LSA are similar other then that its still has more duration the then stock cam.
Old 06-28-2010, 06:40 PM
ColeGraham's Avatar
what are the stock specs on the LS2/6 cams?
Old 06-28-2010, 06:56 PM
vmapper's Avatar
Sure does have more duration... a lousy approx 30 bhp, barely more duration!
Furthermore everyone here is missing the point.
Lobe profile is the proper way to determine difference, not just a peak.
its no different than dyno runs. what good is peak HP when the rest is 40hp lower than a different curve?
Any cam choice should be over 230 both intake/exh or decrease the LSA for a good start.
And a cam needs to be chosen based on all factors from gearing, wheels and mods used.
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
Old 06-28-2010, 07:01 PM
vmapper's Avatar
I would agree the cam on the small side, for sure that is MOST of the problem, along with...
So you did constant speed Tuning on your VE and MAF tables?
(I was just stating there is probably a fraction of power still on the table, but not worth hunting for).
Anyways.. OP - hope you figure it all out.
Quick Reply: V Cam
