Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
bad clutch fluid leak?????? help
Old 01-14-2011, 06:35 PM
atoler27's Avatar
Default bad clutch fluid leak?????? help
i was driving around and clutch was getting shorter and shorter and when i got home it was all the way out and i checked the fluid and empty... and then i put some and pumped the peddle and looked under the car and its all poring out of a little slot between the bell housing and the block.....????????
what to do????
Old 01-14-2011, 06:39 PM
punishmentcycle's Avatar
U need a new slave.. sorry man.
Trannys gotta come out, not too hard if u have the right tools.. best part of it is u don't have to pull the bell housing.. that top bolt is a bitch..
Old 01-14-2011, 06:56 PM
raven154's Avatar
^^^what he said
Old 01-14-2011, 08:18 PM
atoler27's Avatar
would installing headers have anything to do with this problem
Old 01-14-2011, 08:24 PM
atoler27's Avatar
could a bleeder screw be loose or a crew loose that could cause this
Old 01-15-2011, 07:12 AM
CTS-V Shifter Sales
07CTS-V's Avatar
Try tightening the bleeder before you remove the transmission. The new stock slave is expensive for our cars. The list price is about $400, but you can find them for under $300 if you know where to get it. You might consider changing the clutch while you are in there. The LS7 clutch kit (including a new slave) is about $700 shipped.
Old 01-15-2011, 09:13 AM
raven154's Avatar
Headers should have nothing to do with the bleeder. Generally they wont just loosen up but I have seen stranger things happen. Just but a wrench on the bleeder and if its tight, you need a slave.
Old 01-15-2011, 10:01 AM
atoler27's Avatar
yea when i loosened the bleeder it felt like it was already tight but its hard for me to get a wrench back on it to make sure its tightened again soo..... yea i guess imma just have to take it in and have it warrantied
thanks for the help
Old 01-16-2011, 02:33 PM
CancerJCC's Avatar
Don't know about the slave but the clutch itself is usually not a warranty applicable item. (wear item). Good luck.
Old 01-16-2011, 02:46 PM
atoler27's Avatar
yeah the slave is covered but do you think that the fluid could have headed up from the headers and messed up the seal
Old 01-16-2011, 02:49 PM
mikeyc34's Avatar
i have the same problem with mine. i have the parts but too cold to change right now. will come out in the spring. it also gives me an excuse to get the tranny rebuilt. good luck
Old 01-16-2011, 03:02 PM
atoler27's Avatar
heated**
Old 01-16-2011, 03:31 PM
atoler27's Avatar
i just dont want to get it fixed and the same thing happen again, but i have all my headers wrapped and they dont get to hot under there and the hose didnt look to close
Old 01-16-2011, 04:53 PM
raven154's Avatar
No, the slave just go bad from time to time. I've had it happen a couple times. It sucks.
Old 01-16-2011, 05:23 PM
atoler27's Avatar
yea i guess, its just crazy how it happened literally minutes after the install was done.... oh well... crazyness
Old 01-17-2011, 01:47 PM
CancerJCC's Avatar
Perhaps your transmission got jealous that you gave the motor the upgrade so it killed the slave. Now you can give it a new clutch package! j/k Sorry that happened man, sucks having to fix something that isn't for performance.
Quick Reply: bad clutch fluid leak?????? help
