Bolt in 8.8 by creative steel
Ran across this on the other forum more options for diffs is always good.
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-performance/224757-creative-steel-cts-v-8-8-a.html
That's the correct link, just not click-able. Click here.
Exciting; cant wait to see the new pricing.
Thats the issue that I'm seeing. Like people have said, those diff's are pretty cheap at the junkyard. I'm going to guess here and say 100 bucks for the diff and a few hundred to rebuild it so lets say 500 bucks. So the other 3700 (so far) is for the mounting bracket and drive shaft adapter?
Who the heck cares about a drag car? Who wants a 4 door car that can only go straight? Live axles suck. Sorry to be opinionated. This car beats an E46 M3 and an E39 M5 around the Ring. The axles suck. We need to fix it. But not straight axles. If I saw a V with a live axle, I'd expect at least a 20" mullet to be in the driver's seat.
Full set of brackets is 600 plus shipping that leaves to source diff and axles. Which would diff could be sourced for under 150 and i believe custom axles would run around 1500 for 1000hp axles. So 2400 bucks full setup
the key isnt to build a drag car. its to keep the car we have as is, but able to go what we want it to and not fail.
You can't get axles for 500. It don't work that way as you need custom axles but g-force has the ability to make 1000hp axles because they make a inners for the 8.8 diff and outers for our car
They can't make these axles work instead of the 1500 ones? I just don't know much about them....obviously
http://shop.gforce1320.com/product.s...&categoryId=22
