Help the Newbie - 2006 CTS-V with a $2-5k Budget
Hey all,
Long-time forum lurker here. Hoping for some sound advice, given the ridiculous amount of experience that you guys have collectively accrued.
The situation: I have a 2006 CTS-V with 14,000 miles. It's my daily driver, and I'd like to make upgrading this thing my spring project. I have no experience modifying cars (I've rotated tires, installed an iPod kit, etc), but I'm an unusually intelligent electrical engineer with a knack for taking things apart and putting them back together. Point is, I've budgeted $2k to upgrade this car, with provisions to raise that to $5k if I see a point to doing so. I've done about 10 hours of research this past weekend, and would welcome your suggestions. Couple of things:
That said, here are the problems with the CTS-V that I've identified so far:
And some of my potential upgrades, in order of importance:
Couple of final questions:
Thanks very much for your time. I'll be happy to post pictures / videos of my progress later this spring. I have a couple of other, interesting electrical modifications that I'll be making to this car with my own dedicated microcontroller that ties into several systems--but that'll come after the hard stuff is done. If you see it and like it, I may be willing to build additional copies at a small profit.
- Performance is key. I'm focused on the best price/performance (or price per unit driveability) upgrades. If the car looks or sounds better, bonus--but that's not what I'm here for.
- I'll buy whatever tools I need, and I'm patient. But I have to be able to complete each modification in a weekend (20-24 hours working time)--I rely on this car to get me to work on Monday morning.
- A completely legitimate answer to this post is, "don't waste your money." If I have to drop $5k+ in order to really see results, then I'll just put that money toward a 2012 CTS-V coupe.
- The shifter / clutch / flywheel on this car are terrible. The clutchplate / flywheel are at least 20 pounds overweight.
- The intake / exhaust system is too restrictive. Sounds like you can get an additional 40 WHP between new CAI and headers alone.
- The car is too high off the ground, the wheels are small, and they used that unusual 6-bolt hub design.
- Short-throw shifter--UUC or Katech. Roughly $300. No power gains, but big drivability bonus.
- K&N Cold Air Intake. Roughly $225. 17 WHP gain with an easy 90-minute installation.
- LS7 or aftermarket (Spec Level 4?) clutch / flywheel kit. Never played with a transmission before, so I don't know what exactly I'll need. Could use a lot of help here. Sounds like I could trim up to 28 pounds off the transmission's rotating mass. Inertia = 1/2 m r^2, so this should make the car feel quite a bit more responsive.
- Different springs to knock height down by about 1.2 inches. Not sure if I need to get new shocks too.
- Bigger / lighter wheels. I really like the Breyton GTS-R or GTSR-M ($420 each), which are incompatible with the CTS-V's stock hubs. Are there adapter plates and how much do they cost? Is the speedometer reprogrammable, or am I looking at maintaining outside wheel diameter by purchasing low-profile tires?
- Does anyone know the stock (unmodified) WHP output of a 2004-2007 CTS-V versus the output in various states of modification?
- How hard is it to replace a clutch / flywheel? What kind of tools am I looking at buying?
- Are new headers really that valuable? For $1000 (Kooks with X-Pipe), it sounds like you might get an extra 15 WHP. It really only seems useful if you supercharge the engine, because then your flow-rates are going to explode.
- If I buy new wheels, do I need to purchase additional pressure sensors?
- Assuming that I knocked an inch off the CTS-V's ride height, what's the largest diameter tires that you think I could fit without rubbing?
Hey all,
I will say this though. the shifter needs to be replaced, but you could just replace the bushing and see a big result. I have the Pisinuoff shifter which i like.
Also that clutch, flywheel is a giant turd in this car. I would say if you are going to replace it stay away from the spec. I had an issue with a stage 3+ which i wont ever do again.
My car put down about 330-ish hp/tq
you can replace the trans in a day. you would need basic hand tools with a good bit of extensions. Also another set of hands wont hurt.
OBX makes a set of headers which people have been liking and those go for about 500 bucks if i recall.
You might be able to reuse your sensors depending on what type of wheels you buy and i am lowered and run 245 up front and 275 out back... if i recall my rears are 40 not 45 that is stock.
hopefully someone can add the links for the how to's for the various installs since i have to grab some dinner. if not i can toss them up for you.
I've got two or three tutorials saved, including a PDF that details the installation of a LS7 clutch. The low engagement range for that particular installation worries me, plus, why go with a GM design again if the LS2 clutch was so crappy?
1. Replace the clutch. I recommend the Monster level 2: http://www.monsterclutches.com/gm.html
2. Replace the shifter: I recommend the Pisnuoff shifter: http://www.cadillacforums.com/forums...g-process.html
3. Lowering springs. This will make the V handle well and look a lot better. Look for Eibach or H&R springs and MM spacers: PM Nels http://www.cadillacforums.com/forums...m-spacers.html
4. Intake and exhaust: I went with K&N intake, Magnaflow cat back and Kooks headers. Yeah, you can get less expensive headers, but Kooks is proven. Once all installed with tune you are looking at 40rwhp. Kooks headers are the best single mod i've done to my V in my more than 4 years of ownership.
5. I'm lowered with Eibach and Nels spacers. I run 245/40 18 front and 275/35 18 rear Nitto Invos. No issues at all.
6. Dont forget to get axles! I recommend Gforce. He is a site sponsor and also makes the 9" rear for the V. http://www.shop.gforce1320.com/categ...?categoryId=11
I have several videos of my V in different stages pre and post cam. www.youtube.com/whisler151
Thanks for your quick response. Sorry about the total information overload up there--I have more questions that I'm sure most of you have time. Anyway, I don't have a particular goal, other than "have more fun." I get a kick out of honing my driving skills, and I'm beginning to reach the cornering limitations of this car.
he explains in there basically everything he has done to go from a soft squishy car to a proper sports sedan. some of it might be a bit extreme but either way enjoy the read.
http://www.cadillacforums.com/forums...questions.html
but if you have questions we are here to help. just do what you want with the car, be unique if you wish. dont let other people tell you something is too hard or doesnt work. new ideas are what keep a platform alive.
from one engineer to another i will pass on what i think is the greatest V thread i have ever read. enjoy. http://www.cadillacforums.com/forums...05-v-less.html
On a side note, do you not capitalize or place proper punctuation for a reason? Are you lazy because you feel this is the "Internet" and not real life? In my line of work (computer forensics) the way someone posts on line or the activity they engage in on their computer behind closed doors, tells a lot about who they really are. The engineers I have hired are all perfectionists. Posting grammatically like you do would drive them crazy. I guess math is your strong suit and not English.
I actually posted from my phone, then sent it to my pc to upload ( since my phone was treating the links funny). So I had a hard time finding the links, reading the content, eating dinner and also keeping my wife company. My two thumbs were only able to do so much.
Also I am an Automotive Engineer, more so a Power train Engineer lately. My strong suit lies far from grammar. I am not in marketing or some other bs suit wearing field.
Most likely the engineers you work with would not have enjoyed validating engineering issues or putting miles on preproduction vehicles.
But in all honestly typing on the internet properly isnt high on my priorities for my day. I am serious for a large part of my day and I go online to relax.
I am sorry to have offended you.
- Short-throw shifter--UUC or Katech. Roughly $300. No power gains, but big drivability bonus. I have the Katech Shifter, its almost. Got mine for 260 with a CAGS eliminator.
- K&N Cold Air Intake. Roughly $225. 17 WHP gain with an easy 90-minute installation. IMO, the K&N sucks. You will not see 17 rwhp gain with it, and it heat soaks like crazy. I think with the K&N with a Tune you will gain about 6-8 rwhp
- LS7 or aftermarket (Spec Level 4?) clutch / flywheel kit. Never played with a transmission before, so I don't know what exactly I'll need. Could use a lot of help here. Sounds like I could trim up to 28 pounds off the transmission's rotating mass. Inertia = 1/2 m r^2, so this should make the car feel quite a bit more responsive. LS7 is pretty good clutch to go in the V. But unless you plan on turning the car into a strip car (which would require several thousand more dollars to get in there), anything over a 2 is a waste IMO.
- Different springs to knock height down by about 1.2 inches. Not sure if I need to get new shocks too. H&Rs and MM spacers are great, thats what I just installed. Eibach arent bad either, but the only way you will get them now is if they are used. Eibach stopped making the V Pro Kit last summer. H&Rs with the spacers will set you back about $370.
- Bigger / lighter wheels. I really like the Breyton GTS-R or GTSR-M ($420 each), which are incompatible with the CTS-V's stock hubs. Are there adapter plates and how much do they cost? Is the speedometer reprogrammable, or am I looking at maintaining outside wheel diameter by purchasing low-profile tires? Not sure about this, but i like the stock wheels. But what some had done is a 5 Lug conversion using C5 or C6 Vette hubs. which if you do that, you will have a lot more options in the wheel/brake department. If you want to keep the stock hubs, then Wheeldude.com has some for the V. And Lindsay Cadillac has Team Dynamic wheels which are pretty light. And then there is ordering straight up custom built wheels from someone.
- Does anyone know the stock (unmodified) WHP output of a 2004-2007 CTS-V versus the output in various states of modification? Generally between 325-330, from what I have seen.
- How hard is it to replace a clutch / flywheel? What kind of tools am I looking at buying? Like others have said, basic hand tools can do it. But it helps to have a friend when you do it (so to speak).
- Are new headers really that valuable? For $1000 (Kooks with X-Pipe), it sounds like you might get an extra 15 WHP. It really only seems useful if you supercharge the engine, because then your flow-rates are going to explode. Kooks you are paying for the R&D and that they are a name that is one of the best in the business. I havent seen anything that you make less with Pacesetter or OBX, so thats your call. I went with Kooks because they are the best LTs you can buy for the V.
- If I buy new wheels, do I need to purchase additional pressure sensors? Yes and no. If you dont, you will have a TMPS warning light on all the time, and the read out with just say "--". But I dont think you need them.
- Assuming that I knocked an inch off the CTS-V's ride height, what's the largest diameter tires that you think I could fit without rubbing? I have 245/45 in front and 275/40 in the rear with no issues.
and welcome
Ahhhh...back in the day when a jacked up '05 V went for $20k. If that V were for sale now it would go for $10k on a good day.
It doesn't sound like the exhaust is particularly restrictive, save for the cats and obviously the exhaust manifolds aren't as good as actual headers.
The 17hp gain from the K&N seems highly dubious. I did some datalogging of my car in a different thread, and the pressure drop is not that large with the stock setup. There's not 17hp worth of room in there.
You may also want to include some kind of anti-hop axle solution or something for the rear end.
Here's me in all to do over again mode:
B&M
BMR AWH Bushings (no bar needed)
Ipod Kit
LPI CAI (trim out the rubber boot of the factory airbox)
Figure out how far you're going - power adder? Cam? - if not get a diablo - if so - get an hptuner
Use tuner to kill the cags and disable the back o2 sensors
Replace the cats with a test pipe
leave the factory manifolds
leave the bone stock ehaust system
Replace motor mounts at the same time the cats are being removed
Install Monster Stage 2 or 3 with LW Flywheel
Replace the diff bushing
If not using a power adder:
Gforce Axle
Hugest cam ever known to man
Pick your weld-in mufflers (Bassani)
If choosing a power adder:
Maggie kit - with 90MM TB
Upgrade the maggie with a front mount hex
Blower Cam with goodies
Sell off functional diff and axles to poor bastard that can't keep his foot off the gas (me)
Purchase an 8.8" or 9" solution for the rear
Then - Drive it as though it were stolen until the 2nd gen gets down to the $30K range
I probably missed something here... but seems pretty on-track for hindsight.
B&M
Ipod Kit
Gforce Axle
