Current mileage & maintenance
Let's get some current mileage on our old beasts along with warrantY stuff you had to fix along with non warranty
07 V 37,400
-Drivers side catalytic converter
-clutch position sensor
-rear diff seal
-cracked grille
-peeling buttons
07 V 37,400
-rear diff seal
-cracked grille
-peeling buttons
07 V 43,xxx
Not in order:
-3rd diff
-rear diff seal (x2)
-diff bushings
-motor mounts
-peeling buttons
-nav screen cover
-shifter
-spark plugs
-endlinks
-sway bushings
-starter
-sunroof
-sunroof leak
-a pillar molding
-rear sail panels
-headlights
-power steering flush/fluid replace for whine
-seat creak fix
-diff vent tube tsb (twice) for leaking diff fluid
-much more that I can't remember now.
Still under luxury CPO warranty until July 2012...THANK GOD! Running strong now and no current issues. Still love the car.
Not in order:
-3rd diff
-diff bushings
-motor mounts
-peeling buttons
-nav screen cover
-shifter
-spark plugs
-endlinks
-sway bushings
-starter
-sunroof
-sunroof leak
-a pillar molding
-rear sail panels
-headlights
-seat creak fix
04 with 64,700 mi... only had had it for three weeks and so far...
tune up and motor mounts (previous owner new about and compensated for)
bad catalyst (replacing with headers and high flows)
front shocks
peeling buttons
rebuild supercharger
front shocks
peeling buttons
05 w/60k
Motor mounts
(2) radios
pinion seal
passenger seat cover
1/2 synchros
headlight ballasts and bulbs
Both front struts
I know im forgetting something, the service writer printed me out 2 pages of service records...
Motor mounts
(2) radios
pinion seal
1/2 synchros
Both front struts
'05 V w/ 45,000 miles
In order of failure/replacement: (all under warranty)
- Original rear differential replaced, whining. Gen-IV installed & whines sometimes.
- Navigation/Radio replaced, peeling paint on buttons & *****
- Side view mirror switch, peeling paint on switch
- Hood chrome trim replaced, peeling chrome
- A/C pressure sensor replaced & connector replaced/repaired (open circuit)
- (2) tire pressure monitor sensors replaced (dead)
- Reverse lenses replaced, filled with water
- Power steering hose replaced, leaking
- Left & Right HID headlamp/washer assemblies, lens cracking & discolored
- (4) tires replaced/prorated under Michelin warranty, center tread-blocks wore down
- Front brake lines, recalled
- Engine mounts replaced (leaked and loose)
- Starter replaced, internal solenoid connection failed due to exhaust heat
- Starter turn-on lead and connector replaced (connector cooked by exhaust heat)
...besides all of the above the car is great!!!
oh yeah.
06, 51k
Radio button wear
Passenger interior pull handle on door fell off
Pretty sure I need motor mounts.
The dealer I bought it from had to put a new clutch in because they sold it to an 80+ year old man that didn't know how to drive a manual. He put a few hundred miles on and traded for a new malibu...
I feel lucky. If I'd been to this website before buying the car, I probably would have bought a BMW.
BMW is a bad word on this website. Haha. And if you did get a Beemer then you would have to buy expensive snobby clothes too. And maybe a Ferrari watch. And gucci sunglasses. And last not but least. A hot gf that really doesn't like you, but only your car. I really hope there is a BMW owner reading this. Oops
