map sensor
Yep and also log idle kpa with your stock 1 bar MAP to see what kpa you are at before swapping. This way you can adjust the offsets on your new 2 bar to exactly match what your stock MAP read.
The stock 1 bar sensor reads 15.23psi (5volt limit) ... remember sea level 101.3kpa is 14.69psi... so yea, i guess 0.5 psi... is the stock limit... I know Zero FI cars aiming for .5 pounds of boost, so you need a 2 bar sensor. 2.5 or 3.
As raven154 mentioned as well, you need to load a new OS to read the 210kpa limit.
You loose resolution with the Cts-v ECM... going to the 2bar OS. (you have to remember you are now using 10kpa cell jumps, rather than 5.
You mean, ANY BOOST! (not what you said saying beyond a certain PSI that you need a 2bar sensor.. ANY Boost, you need a 2 bar sensor pending your boost levels, end of story.
The stock 1 bar sensor reads 15.23psi (5volt limit) ... remember sea level 101.3kpa is 14.69psi... so yea, i guess 0.5 psi... is the stock limit... I know Zero FI cars aiming for .5 pounds of boost, so you need a 2 bar sensor. 2.5 then 3 if your serious.
So my statement is correct in general terms
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Anyways . . . good info for all
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I have a couple PCM with various tunes for my FI V. One uses a 2 bar MAP from a Cobalt sensor with one side bracket ground off. I can swap PCM easily and just have to be sure the right MAP sensor is in. And retrain the CKP.
