Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
B&M shifter
Old 09-26-2012, 03:21 PM
  #81
Vemon's Avatar
Originally Posted by Onefast V
all the pictures are gone!!! this was such good information!!! CADZILLA please rehost these images, this information is priceless to making the shifter feel much better.
+1 on this...I've been planning on doing some of these mods and the pics would help me out enormously.
Old 10-14-2012, 09:19 PM
  #82
KamaSutra's Avatar
I think your album settings may have been switched to private and that's why the pics are not showing up.
Old 10-15-2012, 03:19 PM
  #83
Cadzilla's Avatar
I am still able to edit the posts so maybe I can fix it.. I did notice the picture number is still in the original hyperlink, which, inexplicably doesn't match the current hyperlink for the same image. You might be right- I don't have the album set to private but I think there's only one "main" folder. Once you create a labeled folder, those might be excluded from public view..
Looking back I think I shuffled a bunch of pics since there were so many in the same folder, not knowing it would affect the forums. If I get time later I'll see if I can repair it one way or the other..
Old 11-04-2012, 01:40 PM
  #84
Stone17's Avatar
Can you fix the pictures?
Old 11-04-2012, 08:16 PM
  #85
GREG O.'s Avatar
Default b&m shifter
me too...ttt
Old 11-11-2012, 09:15 AM
  #86
NIKDSC5's Avatar
Bump for the picture resurrection!
Old 11-11-2012, 03:52 PM
  #87
Stone17's Avatar
Here some picture I took with my T-56 out.
Same cup are above picture.
Old 11-11-2012, 03:58 PM
  #88
NIKDSC5's Avatar
Yup, saw your thread. This thread had picture by picture of how to completly clean up the V shifter w/out going internal into the tranny. Which I plan on doing my clutch/shifter/cs 8.8 all in one shot on dec 18th and I need this thread to make sure I have all my duck in a row as far as what is needed for the shifter.
Old 11-12-2012, 05:07 PM
  #89
lilgcts-v's Avatar
bump for picture resurrection
Old 11-12-2012, 10:17 PM
  #90
Cadzilla's Avatar
fixed
Old 11-13-2012, 10:49 AM
  #91
lilgcts-v's Avatar
im still not able to see the pictures
Old 11-13-2012, 11:29 AM
  #92
Stone17's Avatar
I can.
PM me your email. I PDF the post.
Old 11-13-2012, 12:34 PM
  #93
NIKDSC5's Avatar
fixed
This is by far the best thread on the V.
Old 11-13-2012, 02:18 PM
  #94
NIKDSC5's Avatar
Ok so I immediatly went to home depot to find those parts and Cadzilla was right on, In the electrical Isle about half way down at eye level there they are.
Part # changed but still the same piece, and they cost 48 cents a piece! I bought six just incase I screw up! Here they are...
Old 11-13-2012, 04:11 PM
  #95
lilgcts-v's Avatar
just bought the bronz isolator cup bushing, hopefully it gets here this week or early next week because i have a week off! im so pumped, i just took a before video for you guys ITS BAD how much slop is in my shifter ... this will be the true test.
Old 11-13-2012, 04:21 PM
  #96
lilgcts-v's Avatar
Old 11-14-2012, 09:52 AM
  #97
Cadzilla's Avatar
Good luck guys. Mine is still solid. I had forgotten about how loose it used to be, so last night I paid attention and had to put it in neutral and get close to hear any play because I could barely feel it. I'd say 1/16 inch play, at the ****..which means nearly none at the trans..
Those home depot bushings are a perfect fit..time will tell if heat or stress cracks them... They were originally discovered years ago by a guy on the caddy forum named normv. I think back then they were blue.
Old 11-14-2012, 11:46 AM
  #98
lilgcts-v's Avatar
im gunna see whats what with mine this weekend hopefully i just need to tighten some things up but of my winter break i will probably end up doing the entire fix.
Old 11-16-2012, 05:28 PM
  #99
FuzzyLog1c's Avatar
Confirmed yet again, this time in Connecticut. 48 cents at Home Depot. I bought a half-dozen.
Old 11-16-2012, 05:43 PM
  #100
isis's Avatar
Can these be installed with the trans still in the car?
Quick Reply: B&M shifter
