Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
B&M shifter
Old 11-16-2012, 06:15 PM
  #101
Fuzzy_Wuzzy's Avatar
I don't know that i would call the home depot bushings a "perfect fit" They are a great start but you need to trim the length of the smaller ID down, and sand the outside face to make them fit. I believe i also had to open up the ID a little to make the stock metal sleeve fit. If you have a dremel tool you can make most of the modifications, but realize you will have to cut and sand to fit. (Be careful when fitting as well, the outside lip of the transmission is just a cast aluminum piece that is relatively thin, there should not be any forcing it in (hence a good reason to have some spare spacers in-case you sand too far and it gets sloppy again)
Don't get me wrong, the modification is worth while, and not complicated, but i want you to know they don't just drop right in.
I doubt you can do it with the trans in the car, it would be a very tight fit. It may be possible, but i am not sure it would be a fun experience.
Old 11-16-2012, 08:32 PM
  #102
shadyLS6's Avatar
i tried to get my hands up there to check the linkage. i wanted to see how much play there was at the pin to the center arm that does the actual shifting.. I couldnt get my hands even close..
need a set of these guyse
Old 11-16-2012, 09:31 PM
  #103
FuzzyLog1c's Avatar
That's why I keep saying that we need a "mod party" event where everyone brings parts and we just work like dogs for a weekend. +drinks +grilling
Old 11-17-2012, 09:55 AM
  #104
CTSV_510's Avatar
Replacing these bushings was one of the best things I've done to my V. I had a shop put them in while they were swapping the clutch and they didn't complain too much about getting the pvc ones to fit. I pre-cut them to length for them though. Everyone should be doing this.
Old 11-17-2012, 07:28 PM
  #105
KamaSutra's Avatar
In Chicago I had to head to a suburban Home Depot for those bushings, they were Carlon and not the Cantex brand. I think the inner diameter of the Carlon brand is slightly larger than the Cantex.
Apparently PVC Box Adapters violate building codes in the city and are considered illegal so they don't even offer them in any of the city locations with the only place to get them is the suburban Home Depots.
They didn't even have a "Home" location in the store that I went to and the clerk found them in the electrical section in the high overhead shelf where overstock goes.
Old 01-07-2013, 03:26 PM
  #106
98cobra's Avatar
So who is selling these bronze center pin replacement bushings?
Old 01-07-2013, 03:30 PM
  #107
FuzzyLog1c's Avatar
You mean the #95 bronze isolator cup?
Old 01-07-2013, 03:39 PM
  #108
98cobra's Avatar
No bought that already. For the shifter arm to transmission pin
Old 01-07-2013, 04:09 PM
  #109
CTS-V Shifter Sales
07CTS-V's Avatar
I have them made at a die shop.
Old 01-07-2013, 04:17 PM
  #110
FuzzyLog1c's Avatar
I was going to point him to you if he said "no, I want the other cup."
98, you want the two-piece bronze thing above, right?
Old 01-07-2013, 05:31 PM
  #111
98cobra's Avatar
Yes!!
Old 01-07-2013, 06:22 PM
  #112
GFallen's Avatar
Just curious does this trans have a reverse lock-out? When I have the car turned off it still is a pain to get into reverse. Just wondering, thanks
Old 01-07-2013, 06:38 PM
  #113
odthetruth's Avatar
Yes, but I believe it only cuts in at around 5+mph or so. From a dead stop, you shouldn't have an issue.
What I normally do is go from 4th to Reverse. Seems to work perfect without too much issue. I did that when my mount was going, and even with the revshift mount in it now, I still do it out of habit.
Old 01-07-2013, 06:42 PM
  #114
GFallen's Avatar
Yea I'm gonna install the revshift transmount this winter and see if it helps. I can't believe this thread went this far! Lol
Old 01-08-2013, 09:58 AM
  #115
98cobra's Avatar
Bushings?
Old 01-08-2013, 11:23 AM
  #116
NIKDSC5's Avatar
Originally Posted by 98cobra
Bushings?
Incase you missed this.
Old 01-08-2013, 11:26 AM
  #117
98cobra's Avatar
Who was SELLING THEM? In case you missed this
QUOTE=NIKDSC5;17040460]^^^
Incase you missed this.[/QUOTE]
Old 01-08-2013, 11:30 AM
  #118
NIKDSC5's Avatar
lol ok in case you missed it again, his name is Brian, his cadillac forums name is PISSNUOFF, his ls1tech name is 07CTS-V ....I can hear the wheels turning from here!
Old 01-08-2013, 12:32 PM
  #119
98cobra's Avatar
Please share with us your speed hole bumper modifications. Maybe a thread on your thermostat install? Your contributions to this site won't go unnoticed.
Old 01-08-2013, 12:38 PM
  #120
98cobra's Avatar
Price quote ?
Quick Reply: B&M shifter
