what do you think it will make?
06 ctsv. ls2 milled heads .040 ls7 n cam fast 90 intake k&n cold air, 30lb svo injectors. katech long tube headers no cats. spec billet aluminum flywheel and light weight cover. Dr gas x pipe and stock exhaust.
You're a little off there bud...https://ls1tech.com/forums/generatio...cam-specs.html
LS7 cam - 505 HP - 28 mpg
211 - intake duration @ .050
230 - exhaust duration @ .050
120 - LSA (lobe separation angle) camshaft degrees
120 - intake/exhaust lobe centerline straight up in crank degrees
123 - ILC (intake lobe centerline) factory installed @ 3 degrees retard
.591 - intake valve lift (1.8 ratio rocker arms)
.591 - exhaust valve lift (1.8 ratio rocker arms)
