LS7 Clutch Installed
I just got my LS7 clutch installed today with an LS7 slave. Clutch pedal is right on the floor but I expect that to change. There is some chatter going into 1st and switching into 2nd. The 18 lbs flywheel makes the car feel a lot lighter and it seems to rev a lot faster. How long is the break in period?
![](https://youtu.be/S7bV2j8NnAk)
Total cost. My clutch slipped a little last night and I didnt like it one bit. With around 80k miles I figure I might as well just change it on my terms instead of it go when I really need it.
01_SuperSlow Interesting! How does the car drive with tire pressure as high as you have it?
I have studded snow tires so I doesn't drive well pressures high or not.
dr.duct_mossburg Total cost. My clutch slipped a little last night and I didnt like it one bit. With around 80k miles I figure I might as well just change it on my terms instead of it go when I really need it.
LS7 Clutch w/ 18lbs flywheel $559
LS7 Slave $90
Bleeder (which didnt work) $35
Total Price around $700
LS7 Slave $90
LS7 Slave $90
LS1Tech Premium Sponsor
I love the LS7 clutch and Katech shifter combination I installed in my 2005 CTS-V. It was definitely one of the best mods I have done to my car and I would definitely recommend it to anyone with a CTS-V.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Here's my writeup on the "other forum". Maybe it'll help someone changing out their clutch. (obviously substitute the Monster Clutch for a LS7 clutch)
http://www.cadillacforums.com/forums...h-install.html
There's videos of revving the FW before and after as well. Man the stock turd is such a piece of ****!
Is there an agreed upon power limit for a z06 clutch in our 4000 lb car?
I was reading on some Vette forum and they had ppl w/ 600 rwhp that said as long as you aren't at the drag strip all the time or have drag radials. The tires will spin before the clutch has a problem.
