WTF wheelhop with gforce axle
i don't reply on here much, but i read a lot. As far as wheel hop goes, don't count out your shocks. Shocks control the balance of vertical movement as well as traction and acceleration. I've been part of Racing Teams, from Sprint cars to Road Racing and bad valving on a shock will cause a lot of things, wheel-hop is one of them.
Even if you have brand new FG 2's or FE 4's, the valving in these shocks may not hold up to Extreme Shaft movement. (insert perv joke). Braking the tires loose such as burnouts can overload a OEM shocks even hard acceleration may cause Stock OEM valving to get overloaded. Paired with an aftermarket lowering spring with Higher spring rates will only make this more frequent. You should always match a heavier Spring rate with more shock valving.
The Stock factory CTS-V suspension has always been an issue. Adding one piece such as upgraded axles is a good step, But i would followed up by adding/upgrading the rest of the components.
Just a suggestion, may not be the answer.
-joel
-joel
On 04 05 it the pass side that should be changed
CTS-V Shifter Sales
The diff doesn't matter, the axle shaft diameters were changed in '06.
I'm amazed how many folks are breaking axles, seems crazy to me. I wanted a new DDS single (econo) axle but now I am rethinking that decision.
#33
I had the Hendrix "pro" axles with the race CVs. They reduced wheelhop. On the street. They did NOT eliminate it. On a prepped track, they didn't make a bit of difference. This was with FG2 and all season tires. Don't waste your money on the "pro" axles. They don't do any better than the "economy" axle.
#34
I realize that this thread is 2 years old, but reading on it i noticed some people have been saying something about different sized axle shafts. I bought a pair of G-force axles this weekend, but they dont say anything about "Gforce" on them, and they are two different sized axles??
Is this how its supposed to be?
#37
http://www.google.com.tr/patents/US7938222
#38
Awesome! i think what has been throwing me off is the fact that my axles are already assembled. I've been trying to find a good write up on the installation of the bushings and/or the axles but havent had much luck.
The write ups i've seen talk about having to seperate the oem inner and outer and putting them on the g-force pieces. I've finally figured out that mine already have the inners and outers on them.
#39
I have run just one hendrix axle, both hendrix axles, and both geforce axles. For me, the hendrix axles worked great, with just one and with both, really got rid of the hop. With the geforce axles, I couldn't tell you the difference in stock and these... (although I think the build quality is higher than the hendrix axles. (note i still have the geforces installed and sold off the hendrix axles because i was tired of swapping axles...)
I think it can be very car dependent, I am hoping to get the revshift cradle bushings in soon and see if that helps more.
