Maggie Dyno Numbers
#101
should be targeting Lambda 1.00 for idle and cruise, meaning complete burn.
(I never use Air fuel ratios because fuel isn't usually ideal, e.g. gasoline is 14.681:1 all oxygen and fuel used up in a given volume, however, is it pure gasonline at the pump you just filled up at? what happens when they add up to 10% ethanol? (here is a hint: its not the same any more).
Lambda doesnt care on the TYPE of fuel.
Now we could talk about lean cruise, but Im sure that would just confuse everyone...
#104
Tuned today
For those not watching my other thread...after my tune today I am at 456hp/464tq.
Thats with a Stock Maggie, Comp GT2-3 cam, CAI and full exhaust consisting of Kooks SS headers, high flow cats and Corsa cat back. The Maggie is at a little less then 6 psi boost.
FYI...the initial pull pre-tune was the best of the day(479/472). To bad it was considered an unsafe setup(note - the car had ran for several years that way) with lean A/F and excess timing.
John
John
#106
John
#114
