Head, Cam, Headers, Flywheel & Clutch Install Thread
I just completed a CAM, Head, Flywheel & Clutch Install and fired it up last night, wanted to share some pics and video clip.
The Details:
2004 LS6 CTS-V
Here are pics of the Install:
http://youtu.be/LzU_uu7sQQQ
The Details:
2004 LS6 CTS-V
- PRC 2.5 Heads & Torquer V3 Cam from Texas Speed
- Ported LS6 Throttle Body & Intake Manifold
- Melling high flow oil pump
- IWIS timing chain
- ls7 lifters & lifter trays
- Comp Cam trunion upgrade for rockers
- 160 degree thermostat
- 36# FAST Injectors
- ls7 clutch & RAM 18lb Aluminum flywheel with ARP Bolts, LS7 Slave & pilot bearing
- New gaskets for everything possible and ARP bolts for heads, cam, camplate, etc
- New oem harmonic balancer
- New NGK iridum plugs
- MSD wires
- Pacesetter long tube headers (with cat delete)
- All linkage & cup upgrades on the shifter & trans assembly
- Revshift motor & trans mounts
Here is the youtube video to the first fire up, crappy video but you can get an idea of the new sound she puts out!
Nicely done. The subject of the cam install is near and dear to me right now, since I've got my TRuTorq L3 cam sitting here, awaiting a weekend where I can install it and then take the car to the tuners.
Did you drop into reduced power mode, or do you already have a tune in there that will accommodate that cam well enough to drive to your tuning shop?
When I first fired it up it died immediately and would not stay running. So I drilled a hole in the throttle body to get more airflow at idle and that fixed the problem, no reduced power mode! Which is a really good sign since the tuner I'm going to is about 100 miles away.
Everything is running great with no codes other than for the missing O2 sensors, good oil pressure and temperature. The only thing that is strange to me is the fan is kicking on right away, I think this is related to the new thermostat and my guess is it can be fixed by the tuner.
You'll love it man, I feel like I just bought the car again, whole different attachment to it now that i've got to know her from the inside, haha.
Done it in the past, never had an issue, it's even part of the LS1 how-to-guide. Higher lift cam requires more air flow at idle, the hole is tiny enough that it should be easily compensated for when tuning. Worst case throttle body blade cost $20, way less expensive then a 100 miles tow..
Yeah too low, scraping all the time! haha It's actually just H&R springs with Mighty Mouse spacers, I had a lot of rubbing issues until I rolled the fenders. Nice thing is the car corners like a dream!
Damn, looks lower than H&R's! What size tires u running? Any other pics? I have a set of H&R's and MM spacers both new in box but I've been on the fence about selling them for the GC kit to get the car even lower. May need to reconsider after seeing your pics... Lol
Here are a few pictures:
Looks great IMO! I'm running a 255/40 up front and 275/40 in the rear. Stock overall diameter in the rear and one size wider and one size shorter in the front. Combo looks nice on the car but I may go back to a 245/45 after the spring install if there is more fender gap there than I like.
