Gonna pull the trigger on heads
Total engine airflow cnc ported 225cc trickflow heads with 70 cc chambers.
Getting push rods and arp studs; just trying to decide on rockers.
http://www.totalengineairflow.com/pr...ylinder-heads/
Tried calling them today; but guess I missed them before close.
Going to get that whipple back on.
Nice! Def necessary with the whipple but not a lot of people want to spend $2k or more for heads alone when that is a huge chunk of a 408 build. I won't be doing heads on mine. Cam only with spray and if it blows, I'll spend the money to build a nice 408 stroker setup.
True for NA but flow numbers don't matter so much for FI. I'm not really trying to push every ounce out of the heads(yet) but am more concerned about lowering the compression. I imagine both the TF and ported 317's would perform about the same in my application. Deck thickness on the other hand makes me wonder on better choice; boost pressures aren't going to be high yet but future plans are a consideration too. I guess the question is whether the TF heads are 500.00 better or not?
http://www.texas-speed.com/p-4-prc-s...ted-heads.aspx
They seem to work very well.
What cam are you running? Almost any after market head will outperform a factory casting, so if you have the coin, I wouldn't even consider the factory piece.
TFS requires you to use aftermarket rockers regardless of valve lift, AFR does not. If your cam is on the low .600's I would go with the AFR 220 since you can save money using OE rockers, anything more I would get the TFS castings.
Stock cam right now so lift isn't a problem. I still may choose roller rockers over a trunion upgrade. I think I might give AFR a call; good thing I came here before jumping the gun.
Just wondering if 75cc will be a too much of a compression drop?
You wont be disappointed, TEA did my TFS as cast milled to 62cc cut down and installed ls3 valves for the size of the cam its makes stupid power. Well worth the extra money vs a stock casting.
Just called AFR; they recommend the 235's not sure if the 220's are available' for my engine' the sales guy kept sying the don't offer a 220?
Anyway they also recommend roller rockers but stockers would work; I imagine with a trunion upgrade.
Price on those are 2600.
cheaper if i use stock rockers' not so much if I go with roller rockers.
So AFR with stock rockers or TFS with roller?
Oh yeah and production time is 5 weeks from AFR.
What are you putting them on engine wise? I dunno about AFR but TFS offers a 220/225/235. Generally the 225's are for Ls2/Lq9 and the 235's are ls3/l92. I went with the TFS 220 as casts and honestly I can see the cnc'd versions being leaps and bounds better for the extra 700 dollars. 463rwhp with a mid 230s cam and an inadequate fuel pump is a no brainer. I run the Yella Terra's but Ive heard TEA offers a powdered metal valve guide option that allows you to run stock rockers...and someone said you can "shim" them for the correct geometry.
What I gathered from my conversation from AFR is the 220 heads are made after the L98 but are meant for non LS SBC.
So as it stands now I am going to go with AFR 230 (235 was a typo in my last post) with a trunion upgrade for the stock rockers. Seeing as I'm still on a stock cam they should be fine. I'll go roller rockers when I decide on cam.
I'm also going to get new LS7 lifters and trays; hardened push rods and ARP studs.
I may loose some bottom end with the 230 heads; but that isn't going to matter with the whipple. Plus they are still good heads when I decide to increase displacement.
The price should be around the 3K mark which is about I want to spend.
If anybody has any objections speak now
does this sound like a solid choice?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
For some reason I thought they offered a 220...they have 210, 215, and 230. My bad. Are you staying with stock cubes? What springs are you having installed?
Stock cubes for the forseeable future; but one day its the plan. Didn't get into springs' I was going to go off of their recommendation. They said they were good up to .600 lift; I don't think they would be over 400# open pressure as there upgrades are at 410. I wouldn't mind a little more than stock seat pressure for the blower but not so much that it will wear my rocker tips.
Cant go wrong with AFRs, if you have the money its one of the best set of heads you can buy. Contact Tony Mamo on here he is a vendor and helped design AFRs head and does incredible port work on them(for way more then you wanna spend) but Im sure he would love to talk to you and really get your setup optimized before you make the purchase.
