WTB head lights
WTB head lights
My headlights are foggy, so I'm wanting to replace them. I'd prefer to pick up a set that are smoked but don't have to be. Pm or text 573-450-0465 thanks
I had the same issue with mine....It turned out to only be oxidized on the outside... The worst I've ever seen. I bought the 3m restore kit from O'reilly and it wasn't cutting it so I bought some adhesive backed sandpaper and cut it to fit on the 3m kit. I had to start with a MUCH more aggressive grit than comes with the kit and work my way to finer and finer paper. Took around 3 hours per light but I liked that idea way more than buying a set. If you're gonna buy a set anyway why not spend $20 on some lower grit and try it?
I had my 99 Z28 inspected last month and for the first time in 19 years I was told my head lights would Not pass inspection. I have had them professionally cleaned as well as doing it myself a few times but the oxidation always come back. If it is a Safety Feature that would cause it to fail an Inspection then I wonder why they ever started using them instead of real Glass lamps? GM should be ashamed. Safety First!
Buy these. Depo brand. They are factory replacement, and are wonderful.
https://ls1tech.com/forums/cadillac-cts-v-2004-2007-gen-i/1846763-anyone-try-these-lights.html
You can read my review, see some pics and get the part numbers to search. I ordered a set from Rock Auto.
-Byron
-Byron
TL;DR, The government has said you are dumb and said no glass headlights for you.
That being said, I rather enjoy my 1995 Infiniti G20 with glass headlights and a HID retrofit that looks great with zero beam scatter.
