before I order the wrong things...
can someone confirm this is the proper part list?
Pilot Bearing
Flywheel Bolts 1
Flywheel Bolts 2
(1 or 2)
Balancer Bolt
Pilot Bearing
Flywheel Bolts 1
Flywheel Bolts 2
(1 or 2)
Balancer Bolt
Pilot Bearing
Flywheel Bolts 1
Flywheel Bolts 2
(1 or 2)
Balancer Bolt
Pilot Bearing
Flywheel Bolts 1
Flywheel Bolts 2
(1 or 2)
Balancer Bolt
I'd spring for the ARP crank bolt (#234-2503) and the ARP flywheel bolts (#330-2802).
Your pilot bearing is correct, the same as the truck bearing.
I installed mine without a tool, was a little bit of a biotch but not too bad. If needed, you can rent them from orielly's.
The ARP bolts I used for the Flywheel were 330-2802
I also went with the ARP harmonic balancer bolt due to the fact that I read so many stories of people's bolts backing out as well as not needing to stretch the ARP bolts.
http://www.ebay.com/itm/New-ARP-Cran...#ht_500wt_1180
they rent the pilot bearing tool at any auto zone.. its just a slide hammer with a tip that spreads when u tighten the jam nut.. then just lightly tap it in with a deadblow. i always freeze a bearing before install as it contracts it a bit and makes em easy to slide in..once warmed up its tight as a virgin
