Removing power steering pulley
I'm sitting here in the garage with the POS OEM tool from autozone and not having any luck. I can't keep the dowel straight and the clamps keep on sliding off of the groove. Does anyone have a trick to this? This supposedly simple task is NOT.
The two metal halves don't get tight enough and slip off. I've tried taping them together and wrapping them over and over to make up for some of the space in the ring, but it's not working. I gave up using it.
Also, for those replacing their power steering pressure hose, removing the sway bar makes it possible. It's also a good time to replace those worn bushings. I wish I knew that beforehand.
