Brake Pedal Feel Question
Question: when you park the car, are you able to press the pedal all the way to the floor?
Basically, I'm just questioning my brake bleeding job from earlier (I pulled some air into the master a month or so back). My Motive Power Bleeder did a pretty good job of expunging a lot of bubbles, but I still wonder if actually I got 'em all.
Thanks!
Thanks!
supposedly the abs valves relax/open after 5mph or something like that. I've always wanted to bleed with the car on stands and wheels off..with the wife making sure it doesn't go too fast...but then I have visions of her jamming the pedal and sending fluid everywhere so I nix that idea.
Sounds perfectly safe to me!
I suggest you use a power bleeder. Hassle free and much faster than traditional brake bleeding. Air can get trapped in several places on a vehicle with big calipers and ABS systems. A few simple pumps of the brake pedal won't cut it.
![](http://static.summitracing.com/global/images/prod/large/mvp-0100_w.jpg)
Engaging the abs is about as good as turning up the stereo to get old fluid out. You'll never get it all unless you use a tech2.
If you got air in the abs module a tech 2 is your only hope
