Installing ground control kit this afternoon... Any tips to make it easier??
#61
I'll play with spring rates later. For now, I like where it's at
Lolly... Thanks for the link bud! Maybe I'll tackle those this weekend. I need to do it soon so I won't snap these stockers cause I hear they don't like much drop.
#62
Update...
Car drives and rides great but I'm hearing a squeaking/creaking sound from up front. Any idea what it could be? Something to do with the sway bar from being on stock end links?
#63
#64
It doesn't happen constantly. Noticed it after I took a couple quick turns in the back of a neighborhood and then it happened for a short bit after I straightened it out. So I guess u could say both. I'll try to narrow it down to one or the other when I drive it again in a bit.
#65
I wanted to reply to every post in here but never had time.
Swapping suspension again this weekend, 750th time. Might be a record...
Check this out:
FML! that's a brand new rear fg2.
Check this out:
#66
Sorry this is off topic, but I know THIS^^^ all too well, & all I have is an Eibach kit with QA1's. Both my front fender lips are damaged, especially the passenger side. It's been pulled out about 3-4 times when taking turns into shopping center driveways. I had to physically roll the lip back under with floor jack handle. Bent to hell, pulled out, cracked paint, you name it... It SUCKS, but no way to alleviate the problem at this point, the car needs new fenders now, & they would need to be rolled. The Front fenders honestly should've been rolled under from the factory IMO. Anybody else experience this issue?
#67
