Maggie Heat Exchaneger replacement Price
So I punctured my HEX when trying to install a new alradco radiator.. frustrating to say the least. So I called magnuson expecting a replacement to cost no more than $300. Well turns out a replacement is $900. does this sound right? This heat exchnager is so smaller and simple could it really be that pricey?
if youre looking for a heat exchanger ive got one that iwas gunna use for my maggie but sold it before i installed the exchanger. brand new never even been bolted up or gone more then two feet from the box. lemme know
Or the easiest way is to use needle nose pliers and crimp the bad area and pour JB weld all around. I did that to a very expensive radiator I put a hole in. Its held for a year so far and thats with some pressure. The rad shop could only crimp the bad row.
I got the idea from some drifter buddies that do this all the time. The things you do to to save a $500 radiator. This has held for a year so far and not a weep (knock on wood). No change in water temps either...
Just google aluminum radiator repair and this is very common.
http://www.stockcarracing.com/howto/...r_repair_tech/
