Projector Halo Headlights & Foglights
#101
Now, long time ago, this story ends with mixing oem and halo aftermarket parts together to one lamp, here are the result from this project:
Some words to this action: Put in the brightest COB rings i can get with diffusion disc in front of them, so you canīt see the yellow glue, where the ledīs are fixed on the ring!
Then made a adapter sheet to match the oem D1S light system to the halo bracket into the lights with some spacers etc., a lot of work to do here to get everything matching!
I think, they are the brightest DRLīs like the DRL on newer BMWīs, but caused of my black tinting, they doesnīt look so bright, as they are w/o the black tint and the D1S action was also worthless instead of the 55W HID kit i installed before, bec of brightness from the lights are still the same, so the next action here to get it brighter is still waiting...
Regards,
Ronald
Regards,
Ronald
#102
where did you get the chrome housing only im trying to buy one but cant find that piece only
Regards,
Ronald[/QUOTE]
Regards,
Ronald[/QUOTE]
#104
#105
Unsure if they are still available in ebay as I bought them few yrs ago, I can choose between chrome and black inner, can't believe, u can buy the inner separate...
Maybe try another marketplace like Amazon or try Mr.Google to find them w/ chrome inner...
Greetz
Ron
Greetz
Ron
#106
What wiring changes are necessary to go LED with Halogen housings?
So it is long since time to replace the V's headlights. I went with Halogen housings off Amazon and then picked out some matching color range LED Hikari bulbs for high, low, fog, and running lights etc.
As I'll be coming from the OEM harness built for HID over to the Halogen style (now LED) headlights should I be expecting to have to pull pins/plugs and rewire the OEM harness? Curious as I assume I;ll still be only working with the one long block connection. Anyone have a DIY on this part of the process? I hunted but didn't see anything on the forums about it.
#107
#108
Thanks sir - will grab some before and after shots
Thanks sir - will five in with both feet then. Just want the headlights up to par as I just shot the front bumper and am taking it to clear bra next week.
#109
#110
It was a long night under the V last night but overall went ok. This is my first time tearing off her beak, it wasn't the most enjoyable thing I've done albeit not that terrible. Everything was plug and play with exception of one of my high beam bulks that is out of spec on diameter and didn't fit the housing. I tried swapping across lights and the single bulb was a problem regardless. Waiting on a replacement, then to tear it all down again. I need some night driving time to see how happy I am with it. Otherwise brightness and beam pattern seemed really nice by comparison to my former setup.
#111
