Teaser Pics....
Thought I would share a few pics since I am nearing completion. I have to be honest, it took a while to figure out where to mount the HEX pump, but it's in there attached to a home made bracket (old filing cabinet lid, LOL) using the PCM mounting bolts.
I still have to insulate all the HEX piping but the mock up is done. I also have to wire the HEX pump and load the base tune before I can fire her up. I'll be doing a build thread in the coming weeks, just wanted to show off a little!
I realize the e-force is rather new but are they a huge improvement over a maggie? Are they going to be able to feed larger cubic inch motors? Also heat? I see it runs a large cooler, Hopefully that helps.
Also, would this be a better way to go than a modified GTO Procharger kit?
Sorry I'm curious about these and I have done zero research as yet.
Looks great though! Cannot wait to hear about the results/opinions. Especially since you were previously maggied.
Yes, huge improvement in every conceivable way. You cannot really compare a roots and a centripetal supercharger, each has its own faults and weaknesses. A roots type will have more torque for the street and will never be able to compete with a centripetal in terms of all out performance.
The larger, more efficient rotors with the vastly improved intercooler (over the Maggie, that is) will make more power at the same boost. The only hindrance with the E Force is the long runners (what makes it a torque monster) can choke off larger motors at higher RPM's. The most I'll ever go is a 383...so that didn't matter to me.
The HEX is the largest one they have at FrozenBoost.com, hope it really helps with the IAT's! What you can't see in the pics is that its 3" thick.
Turning out great man... HEX pump install looks clean. I've also been told it doesn't feed large displacement well, but I agree it's a huge improvement over the Maggie for the reasons listed
My thoughts...if you want to run a big inch motor with a TVS (ESP an E Force) make sure you have at least a 4.125" bore so that you can use LS7 style heads and get the blower for that port style since they make them.
It would be nice if Edelbrock would weigh in on this, but I have never seen them comment on anything.
Nice build. Can't wait to see dyno results. Did you just pull the maggie off to install the Edlebrock, or did you build another motor for it? I would like to see what TVS would do on 4.0in+ bore with some LS3 or LS7 rectangular port heads.
There are one or two users stalking this forum with 750 RWHP CTS-Vs using 418 CID LS3s, LSA heads, and TVS2300s at 12-14 psi. I was sent several PMs after I outlined my projected build. Apparently, fueling that kind of beast requires quite a bit of engineering, since the ramp rate is intense.
DMM, damnnn!! that TVS fits in the bay nicely, does it look like a kit is feasible?
Are you running the V2 motor mounts? it looks like from the pics you posted a while ago, all that is needed is a block adapter like the iron block transplants have to use.. i want to go back to oem mounts..
pics or they dont exist
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
Don't know about a kit...it's a no brainer for the LS2 guys, a little more work for the LS6 guys. I decided on the V2 mounts after the install as I wanted to k ow how it fit with the CS mounts first as a baseline and since most are using these mounts. I'll get back on that horse soon enough and probably lower the engine a bit in the process after the 8.8" kit install.
pics or they dont exist![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
yea i was just thinking kit b/c of that other thread where that vendor kept on asking the same question.. please let us know what has to be done to get this to work with ls6.. i thought the only thing different was the 90TB and adapter.. no rush just wanna know how to make it work..
LS2=90mm TB, crapier intake, bigger cubes. With out getting very technical.
Nah...just pulled the Maggie. Motor is stock at the moment save for .650" valve springs, HD pushrods, and ARP head bolts. Wanted to start with a baseline first, hen add a cam that I have on hand at the moment (.603/.610 223"/232" 113 LSA) and see how it does since the E Force can handle the overlap.
I could have made life a easier on myself if I had gone with a smaller HEX pump and used heater hose vice the insulated aluminum lines...but like I said, i'm a little OCD when it comes to this, LOL!
One thing that I really like about the E Force is the pulley setup, it's very well thought out and wraps the pulleys much better than the Maggie did.
I am one of the guys running 750+ RWHP in a cts-v. Mainly just dyno time but with a tvs 2300 and a 416. Its a long list of parts though to get there....
It does exist. Just wanted to chime in on that.
And thanks for sharing!
