Bad ABS Sensor - Service Stability System?
I picked up a "Service Stability System" message in the DIC after hitting a moderate bump in the road this week. What are the chances that this is a case of the connector working itself loose versus needing a new wheel bearing/ABS assembly?
If I need the latter, would you recommend OEM GM parts (roughly $260 for a pair), or one of the various aftermarket parts (roughly $75 for a pair)?
I've had an intermitant problem before (hitting bumps would trigger it sometimes) cleaning the wheel sensor conection in question with a small needle file corrected it, but I have a reader that will tell me the code for specific sensors.
If you do end up having to replace one of the hubs, RockAuto has the Timken HA590079 for $130.79 a piece.
I had the same issue in my car and it actually ended up being that the harness that routes along side the radiator on the passenger had rubbed through the shielding causing it to short out occasionally. I'd have to thank the previous owner for that one.
