Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Seal between the driveshaft and transmission
Old 03-11-2013, 09:56 PM
Chrismikeb's Avatar
Default Seal between the driveshaft and transmission
Was under the car changing oil, noticed tranny fluid all over the resonator. Appears to be coming from where the driveshaft enters the transmission. Anyone have a specific name for this seal or part number? Is it the rear main seal? Also how much of a bitch would it be to change? Doesn't look too bad.
Old 03-12-2013, 07:28 AM
05txctsv's Avatar
trans input shaft seal?
Old 03-12-2013, 07:48 AM
Stone17's Avatar
GM Output Shaft Seal part #89059483
http://www.tickperformance.com/gm-ou...al-some-cts-v/
Old 03-12-2013, 08:41 AM
MacLEAN's Avatar
Should be really easy to replace. Drain the ATF, pull the drive shaft, pull the seal, set the new seal, replace the drive shaft and ATF, done.
Old 03-12-2013, 09:26 AM
CTS-V Shifter Sales
07CTS-V's Avatar
No need to drain the fluid to replace the output shaft seal.
Old 03-12-2013, 12:17 PM
Stone17's Avatar
Unblot the tailshaft and remove.
Old 03-12-2013, 12:20 PM
Chrismikeb's Avatar
Thanks for the link.
And if I don't drain the fluid, won't it spill out of there? The car will be with the front end lifted up.
Old 03-12-2013, 12:43 PM
ssgunny's Avatar
If the front end only is lifted up then some ATF will drain (not sure how much) once you pull the shaft. I had the car in the air (rear slightly higher) and a just had a few drips when I replaced my DS. I say get it up as level as possible.
Old 03-12-2013, 01:23 PM
Chrismikeb's Avatar
Ill just drain it first, who knows the last time it's been changed.
Old 03-12-2013, 02:15 PM
itsslow98's Avatar
Yea drain it for sure. It can only help to put fresh fluid in it.
Old 03-15-2013, 02:40 PM
Chrismikeb's Avatar
Do these driveshafts just slip into the tail housing? Or will i need to take off the tailhousing? Seal should be here tomorrow.
Old 03-15-2013, 07:10 PM
01_SuperSlow's Avatar
It just goes into place. No need to remove tail housing.
Old 03-15-2013, 07:25 PM
Stone17's Avatar
Make sure you use green loctite on the driveshalf bolts.
Old 03-15-2013, 08:05 PM
Chrismikeb's Avatar
Green? I thought they only had blue for hand tightening. And red for a stronger hold.
And thanks for the info. Me and surprises don't get along.
Old 03-15-2013, 08:32 PM
Stone17's Avatar
Green loctite prevents vibration loosening.
You can use blue or red.
Make sure you mark where your driveshaft is before you remove it!
Old 03-17-2013, 01:56 PM
Chrismikeb's Avatar
Got the exhaust out, got the drive shaft unbolted. Wasn't expecting to find a 30mm nut holding the trianglular piece (that the driveshaft bolts onto) to the transmission. Pep boys, homedepot and lowes don't stock a 30mm deep socket.
The seal I need to replace is right freakin there!!!
Old 03-17-2013, 02:15 PM
jclayc's Avatar
try advanced auto, they had a whole row of weird sizes last time I went - surprised me
Old 03-17-2013, 02:19 PM
FoD
FoD's Avatar
Also, look into getting a Trans Mount replacement. Yours looks a bit flat.
Old 03-17-2013, 02:43 PM
http://www.sears.com/craftsman-30mm-...1&blockType=G1
Sears has it.
Old 03-17-2013, 03:20 PM
itsslow98's Avatar
If you have an autozone around you they rent a bunch of special tools including sockets so you get to use it for free. I do it all the time.
Quick Reply: Seal between the driveshaft and transmission
