Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What did you do to your V today?
Old 01-26-2018, 02:27 PM
  #1981
raven154's Avatar
Originally Posted by BudRacing
If the V was in the Simpsons.
Old 01-26-2018, 10:37 PM
  #1982
actrite80's Avatar
Originally Posted by raven154
Haha that's ******* awesome
Old 01-27-2018, 03:59 PM
  #1983
AAIIIC's Avatar
Originally Posted by AAIIIC
- Not today, but forgot to share this one a month or so ago. Nice dent on the top of the driver side fender - someone dropped something pretty heavy on it while it was sitting in a lot on the Army/Marine base for a few weeks. Dent is probably ~6" long; fortunately it's not on the crease at the top of the fender, so maybe a PDR pro can take care of it. Haven't looked into that yet.
Still haven't talked to a PDR guy about the dent , but today I did snag a "new" fender at the junkyard. Guy at the checkout was former Army, and hooked me up since I'm active duty - free fender . It's not the right color, but it's straight, so if the existing fender can't be corrected by PDR, I'll have a nice one to get painted and install in its place. (I think the dent is probably not fixable by PDR. I said months ago that it's not on the crease, but if I run my hand along the outer face of the fender, I can feel it's been bulged out slightly there at the dent.)
Old 01-29-2018, 01:19 PM
  #1984
Byron's Avatar
Cleaned my new to me volant Cai that made the journey across the pond.
Doesn't add power. I didn't expect it to .It does however allow me to pass the inspection for my modified car registration .
It does rev much freer and under part load it revs as fast as at idle. Very happy with the setup.
-Byron
Old 01-29-2018, 02:36 PM
  #1985
rjoffe's Avatar
I saw the first pic, and my first thought was:
"Please oh please, no mudflaps"
Whew !
Old 01-29-2018, 07:07 PM
  #1986
vroom_vroom's Avatar
got me a roll of 1in i.d. insulated heat shield tubing for the alternator wire (and fuel line on the t/a) and got me a new dei battery blanket. hopefully it will not cook as fast would like to avoid the battery relocation to the trunk.
Old 01-30-2018, 08:04 AM
  #1987
1CL3ANSUP3RSPORT's Avatar
Doing rear cradle bushings along with diff bushing and block. Since the car is in the air I will work my way to the motor and trans mount as well, how fun!
Old 01-30-2018, 01:37 PM
  #1988
Choppy_Idle's Avatar
Bought some sticky rear tires, Yokohama Advan Neova AD08r semi slicks in 265/40-18:
Greetz
Ron
Old 01-31-2018, 01:18 AM
  #1989
Byron's Avatar
Got the break in gunk flushed from the new trans. Drain and filled the 8.8 with ford racing oil 75-140 plus 4oz additive .
Fixing a clearance issue with the exhaust so it will quit tapping on the subframe.
-Byron
Old 02-02-2018, 02:43 PM
  #1990
westwopper's Avatar
My CTSV's Diff got some new fluid today during lunch , and some fresh oil for the engine!
Update:
Used Mobil 1 LS oil in the diff and my rear gear is QUIET. It sounded like I had bad hubs since I've owned it. I hope it stays like this.
Old 02-02-2018, 11:40 PM
  #1991
Byron's Avatar
Took the car, bad DSS axles and all and flogged it all the way up Jebel Jais in Ras Al Khaimah yesterday.
Spent some quality time with the misses and got some fresh air. The tranzilla is absolutely straight beast and smooth as glass.
-Byron
Old 02-07-2018, 03:02 PM
  #1992
NIKDSC5's Avatar
Ahh the upside down lower grille, that brings me back.
I changed my oil because i either popped a head gasket or because my car is a garage queen and is rarely ever driven hard lately, there was water in the oil. yay.
Old 02-08-2018, 02:07 AM
  #1993
Byron's Avatar
Probably going to stay upside down until I install the new fogs in a month or two.
-Byron
Old 02-08-2018, 10:25 AM
  #1994
heavymetals's Avatar
Ordered a new battery.
My 10 year old ODYSSEY is not holding a full charge anymore.
Old 02-09-2018, 06:42 PM
  #1995
westwopper's Avatar
How much water? Coffee with cream and sugar look or worse? Cream and sugar is not too big a deal
Old 02-09-2018, 06:54 PM
  #1996
westwopper's Avatar
Just changed my trans fluid. I believe it was a 22MM wrench for the temp sensor for those without an American wrench handy. Then I filled it with Pentosin FFL-4. I know, not d/m III. This was recommended by an appropriate source. Any issues and I'll post. It shifts nicer than before
At 65k miles I have fresh:
GM cold climate PS Fluid
Mobil 1 gear oil
Fresh fluid in my clutch hydraulics - amazing difference in pedal feel.​​​​​​
Fresh transmission fluid
Next is:
replace buttons on radio and screen
Repalce tail shaft seal + check the carrier bearing
dream of headers....
Old 02-11-2018, 09:06 AM
  #1997
kra86's Avatar
Mobil 1 gear oil
Next is:
Sounds like you and I are at the same point in owning / maintaining our CTS-Vs.
Drove mine yesterday, nothing much to report during winter.
Old 02-11-2018, 05:12 PM
  #1998
westwopper's Avatar
Yup. Minor updates while keeping it healthy. today I protected my passenger backseat from my little guy.
these are available from your local Audi Dealer...
Old 02-13-2018, 08:15 PM
  #1999
kra86's Avatar
Minus that part about the little one. None of those on this end. Hehe.
Old 02-15-2018, 04:19 PM
  #2000
Camaro350Z28's Avatar
Got my creative steel trans mount in. Stock mount was definitely bad, but now it feels like my motor mounts may be shot. Going to order those.
This weekend I will be doing new brakes front and rear, will have a review on the duralast gt pads. Also got my threaded stick and creative steel shift ball to install.
Quick Reply: What did you do to your V today?
