Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What did you do to your V today?
Old 01-12-2020, 07:33 AM
  #2741
SE-R Spec's Avatar
The crank case is vented through the pcv system into the intake and therefore can pull in unmetered air behind the MAF causing a lean condition
EDIT: Byron beat me to it
The following 2 users liked this post by SE-R Spec:
Byron (01-12-2020), westwopper (01-12-2020)
Old 01-12-2020, 10:46 AM
  #2742
Byron's Avatar
Replaced the reservoir cap. Removed it to check fluid levels and it broke into 5 pieces. Kinda neat to see how it works. Not neat to see the big spring launch over your head.
-Byron
Old 01-14-2020, 09:19 AM
  #2743
rjoffe's Avatar
Originally Posted by westwopper
there is one Sunday mornings at Dog Money in Leesburg. Small but I like it.
Times? Link ?
Old 01-14-2020, 10:08 AM
  #2744
84FSP's Avatar
Order the rest of my bits to go back into the motor and replace a dead 5k mile GM LS7 lifter. Taking the opportunity to add a bigger cam and a Fast intake. Curious to see how many more ponies that brings.
Old 01-15-2020, 11:48 AM
  #2745
Byron's Avatar
Trouble shot my MAP sensor. It's dead.
​​​​​​New one arrives soon. It's an intermittent failure, so it was as though the problem was with the O2 sensors, but the actual problem was the MAP.
I tapped on the sensor and the car ran perfect, until it moved out of its zippy happy position. It was causing the car to run rich and from that it also threw codes for O2 sensors.
I am super excited to see what she will do come Dyno day next week or two.
-Byron
Old 01-16-2020, 10:04 AM
  #2746
Byron's Avatar
Got my VLM wheel today. Super happy with it. It's larger than the other wheel I had and just slightly smaller than the stock wheel.
Doesn't smack my knees on the wheel anymore. And the carbon fiber is a nice accent.
-Byron
My old one.
With the non carbon fiber switch panel.
Old 01-16-2020, 04:42 PM
  #2747
SE-R Spec's Avatar
Byron, what radio do you have? Also is that an AUX cord coming out of your ashtray?
Derek
Old 01-16-2020, 07:01 PM
  #2748
Byron's Avatar
Derek
I have the stock radio. That's a USB power cable, wired into the cigarette lighter.
-Byron
Old 01-16-2020, 07:50 PM
  #2749
westwopper's Avatar
Sent PCM off to Tuned by Frost for headers, rear gear, etc.
This is the first car I’ve had a tune on so I’m excited!
I will be putting my PCM back in with more protection / insurance/ when I get it back.
The following users liked this post:
Byron (01-17-2020)
Old 01-17-2020, 05:40 AM
  #2750
Byron's Avatar
Got some better pictures in the sunlight. Carbon fiber is perfect. Not too much and not too little. And no annoying reflection.
-Byron
CTSM (01-17-2020)
Old 01-17-2020, 06:42 AM
  #2751
kra86's Avatar
I like the new steering wheel. Very nice.
Byron (01-17-2020)
Old 01-19-2020, 06:58 PM
  #2752
AAIIIC's Avatar
Finally got the A/C recharged. I'm not sure it's "right", I'll have to wait for warmer weather to see how it does. But it was blowing cold enough air to indicate the system is working, which means I'll have the very important ability to defog over the next couple months.
Byron (01-20-2020)
Old 01-20-2020, 11:44 PM
  #2753
Byron's Avatar
My car had a bad map sensor, which killed my O2 sensors.
Replaced the map sensor, and tried to clean up the new O2 sensors. Nope they are dead.
New sensors inbound and arrive Thursday, plugs arrive sat as they are thrashed also.
Everything else is fixed in the entire system, but cleaning alone was not enough to save the O2 sensors, so in my parking spot it will sit until the parts arrive.
Moral of the story is if you throw a MAP sensor code, park the car or it gets expensive quick.
-Byron
Old 01-23-2020, 10:21 AM
  #2754
Byron's Avatar
New O2 sensors arrived. This is 8-10 min of drive time on the dead o2 sensors. They were cleaned sun afternoon and reinstalled and the car parked.
If you have a bad MAP sensor, park the car and replace it ASAP!
She is back in beast mode. New plugs (TR55ix at tuners request) going in first thing in the morning.
Changing from TR6ix plugs which are now filthy.
There is also a huge difference in design from the Delco and the Bosch listed interchange o2 sensors. Buy the Delco O2 sensors.
They are better. You can see the difference between the end of the sensors. The Delco has a smaller opening, and doesn't protrude as far into the collectors. This may or may not have been a contributor to their failure. I am not well enough versed in O2 sensor designs to be an authority however, so your mileage may vary.
Car runs better now and is holding a much tighter afr than it did with the Bosch sensors that were installed 5 Dec 2019. (map sensor was still good at that time)
Also for those with kooks or considering kooks, delcos fit without extension if you unclip the harness from the rear of the block. Fits perfectly that way, safety clip and all with about an inch of slack, so nothing is overly tight.
-Byron
Old 01-24-2020, 08:52 AM
  #2755
Byron's Avatar
New plugs in, didn't touch the gap, TR55IX runs smoothly now.
Tomorrow the 4" with ls7 maf is going in, and the MSD 88867 harness for the coil packs.
If you guys don't have one yet, the gear wrench universal sparkplug socket is a life saver and makes quick work of the task.
-Byron
Old 01-25-2020, 11:46 PM
  #2756
Byron's Avatar
Got the msd 88867 harness installed, seems to be functional and idle seems to have improved ever so slightly. Once my tune is adjusted for the 4" tube and ls7 MAF I'll try it connected and unconnected and Dyno day I will do a pull without it and a pull with it.
I'm not actually expecting any HP from it. Just for science since I'll be renting it for an hour. Essentially it provides a cleaner, more stable voltage source to the coil packs via 12ga wiring and the relay. That's the theory. It did ever so slightly help idle, so there may be something to it.
If I decide to keep it, I'll clean it up a little better than it is now. If not it's easy to reverse. Relay is zip tied to the strut bar. If I keep it, it will be routed to the firewall.
-Byron
Old 01-27-2020, 08:58 PM
  #2757
Byron's Avatar
Ls7 MAF and 4" tube was a success.
She rips now, still have some dialing in to do.
It's ugly right now, but I will cerakote c7600 coat it, then use black silicone elbows to improve the appearance somewhat.
I still need to hard wire the MAF wires, and trim the boot somewhat more, but it's functional now So I am able to focus on other things and come back to area beautification later.
I am using a K&N dry filter, part number is the last image. It's way easier to clean and maintain compared to the oiled variety, and cheaper by a few bucks.
-Byron
Old 01-28-2020, 09:14 AM
  #2758
84FSP's Avatar
What wheel is that? IS that a Gen 2 or 3 wheel? Did everything transfer over - all the buttons work etc? Looks really sharp.
Old 01-28-2020, 09:23 AM
  #2759
Byron's Avatar
Thanks, it's a VLM wheel from VLM auto on Instagram.
If you are in the Facebook page, V1 vs world, a guy is running a group buy on them. I'm super happy with the wheel and the carbon fiber is nice also.
-Byron
Old 01-28-2020, 06:43 PM
  #2760
SE-R Spec's Avatar
Are you allowed to put a price up on that group buy?
Quick Reply: What did you do to your V today?
