What did you do to your V today?
#1201
Got the engine out finally, just need to make a few repairs on the AC Electrical connection and a nipple on the radiator. Then swap some stuff from the old engine to the new engine over, hopefully I will get it in tomorrow. Got the transmission pulled apart by Jason at TDP, everything look good except for my 6th, engagement teeth were wore out bad, hopefully that will fix my issue of popping out of 6th and vibes near 80 mph.
So for now, the fastest thing in my garage is my wife's Schwinn
#1205
Was a little depressed with the build quality but on the up shot it has surprisingly nice cut off lines with hids in them!
Got my butyl mat on the drivers door, use a little around my control switch and map pocket and wouldn't you know. Dead quiet. Need to pull the package tray and hit that up but I keep getting tied up with the bird
#1206
Started modeling an upper control arm for the V1 in Solidworks. This will adapt to the C6 Corvette spindle, which weighs 5.8 lbs. The cast iron V1 spindle weighs 13.1 lbs and the aluminum STS-V spindle weighs 8.7 lbs, for comparison.
#1209
#1215
The Wilwood PMC is now available. You receive a comprehensive master cylinder kit along with all the hardware and fittings to adapt to the 1st generation CTS-V. This clutch master cylinder kit replaces the factory unit to provide full disengagement and faster engagement of aftermarket and OEM clutch systems. Paypal $300: jaysenbaker@gmail.com.
#1216
