Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
I have cured the wheel hop in my 2005 CTSV.
Old 02-01-2014, 12:45 AM
54inches's Avatar
Default I have cured the wheel hop in my 2005 CTSV.
Pictures when I wake up in the morning.
Old 02-01-2014, 05:48 AM
raven154's Avatar
Well that was disappointing lol
Old 02-01-2014, 06:26 AM
TeamSorad's Avatar
troll thread =)
Old 02-01-2014, 06:59 AM
LS BRAVADA's Avatar
Your a rearend tease
Old 02-01-2014, 07:42 AM
ravenls6v's Avatar
I assume this has something to do with the sub frame braces 54 was working on
Old 02-01-2014, 08:28 AM
MrAkalin's Avatar
I've seen on FB and ctsvowners. It is the subframe connectors! I'm interested
Old 02-01-2014, 10:43 AM
StretchASU's Avatar
If this really did work I am interested in a set. Just don't have the time to fab them myself right now.
Old 02-01-2014, 11:21 AM
54inches's Avatar
Yep, I did 2 wet burnouts on asphalt, one dry on on asphalt and 2 on dry flat and level concrete.......Nothing but smoothness.......
Notice the tape measure in the back ground.....
Old 02-01-2014, 11:27 AM
LS BRAVADA's Avatar
I'm in paint mine semi gloss black tho
Old 02-01-2014, 11:32 AM
raven154's Avatar
Looks a little different but functions the same as the old KARS brace. I have one on my car and it does work well. Doesn't do much for the wet asphalt though.
Old 02-01-2014, 11:39 AM
raven154's Avatar
Ties the front cradle mount and trailing arm mount to the body.
Old 02-01-2014, 11:41 AM
isis's Avatar
Installation requires welding for the front plates right? So not 100% bolt on? Any way around that?
Old 02-01-2014, 11:46 AM
54inches's Avatar
Originally Posted by TeamSorad
troll thread =)
You guys crack me up; lol!!!!!
Cool! Mine for my personal car is nothing like the KARS kit though. KARS appears to just handle the cradle and is more of a lateral bracing as mine is more of a Subframe connector. Make sense? Have any photos of it installed on YOUR car? Can't find any online installed.
Old 02-01-2014, 11:51 AM
FuzzyLog1c's Avatar
Frankly, I think you could've gotten the same effect if you installed Revshift subframe bushings. And, at this point, you don't have any of the advantages of having a subframe because you connected the subframe to the body.
That said, I like the connection point on the body. Have you looked into building an X-style brace to stiffen up the body by itself?
Old 02-01-2014, 11:55 AM
90G60's Avatar
I too would like to know the answer to this ^^
Knowing you can't talk about it here, you should send links to somewhere that we may be able to pre-order.
Old 02-01-2014, 12:02 PM
54inches's Avatar
I think experience has proven that bushing replacement does not cure wheelhop in others cars. I have already talked to RevShift about making Al rear subframe bushings and if they are not down, we are going to have them built.
I don't think we removed ANY benefits of the subframe, but that is just my opinion. Car rides just the same with very little extra noise if any. I really cannot tell if there is any. And to correct your statement, we SUPPORTED the subframe at the front to reduce the natural rotation moment of the cradle to reduce wheel hop.
As always, I look forward to your fuzzy logic and point of view as it really gets me to thinking about improvements, utopian situations and worst case scenarios. Thanks bud!!!!!
Old 02-01-2014, 01:00 PM
maroman88's Avatar
looks great!
Old 02-01-2014, 01:32 PM
StretchASU's Avatar
So any chance you guys are going to make this as a full bolt on kit? Because not many people have the know how or capabilities to weld the re-inforcement plates you guys look to have made. Just a set of blind rivet nuts inserted into the unibody won't get it done in the long run IMO. Over time I would bet that area begins to get stressed and the aluminum would crack if the car is driven hard on a regular basis.
Old 02-01-2014, 01:38 PM
54inches's Avatar
I did not feel that would be safe for my car, so I welded these in for my car.
Old 02-01-2014, 02:21 PM
BudRacing's Avatar
Wow, This looks like a killer solution. I'm surprised it took us all of 10 years to figure it out!
Even if it does require a little bit of welding, it would be totally worth it to take it to a shop to have done. It also wouldn't cost a bundle. The rest is just bolt-on.
Quick Reply: I have cured the wheel hop in my 2005 CTSV.
